440 source water pump & housing, big block, review ??? #2050106
04/09/16 12:38 AM
04/09/16 12:38 AM
colorado
cocamcuda Offline OP
colorado
any body using this combo ,good results ???.any problems ??? thanks jim
Re: 440 source water pump & housing, big block, review ??? [Re: cocamcuda] #2050173
04/09/16 02:43 AM
04/09/16 02:43 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have their pump & housing on my 512 with AC, I am in south Texas & car runs nice & cool.
Re: 440 source water pump & housing, big block, review ??? [Re: CSK] #2050307
04/09/16 11:30 AM
04/09/16 11:30 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Running both on my 68 GTS here in Arizona. No problems so far
Abe Lincoln
Re: 440 source water pump & housing, big block, review ??? [Re: cocamcuda] #2050392
04/09/16 01:52 PM
04/09/16 01:52 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
I'm a fan of the GMB pumps they build them for Milodon basic pump is on Amazon and EBay for $25... The pump housing are as good as any. Just watch for core shift causing a narrowing. It was an issue a few years ago on the offshore aluminum housings
Edit: the GMB is also availble with a cavitation plate the part number is 120-1200. For the plate version add a "p" that one is identical to the Milodon, even has the GMB cast in it. They're Japanese built not China last I saw. .02
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 440 source water pump & housing, big block, review ??? [Re: dart4forte] #2050437
04/09/16 03:23 PM
04/09/16 03:23 PM
is that one of their "scroll" curved impeller vane pumps? I have one but ain't got that far yet (451)
Re: 440 source water pump & housing, big block, review ??? [Re: cocamcuda] #2050748
04/10/16 01:16 AM
04/10/16 01:16 AM
fresno
hyefatman Offline
hyefatman  Offline
fresno
had to remove them from all my big block cars... total junk car will over heat when idling works fine in drive mode... 440 source knows of past problem but refused my refund on 5 units replaced with Milodon
http://www.dodgecharger.com/forum/index.php/topic,60599.0.html
Re: 440 source water pump & housing, big block, review ??? [Re: hyefatman] #2050915
04/10/16 11:25 AM
04/10/16 11:25 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
My 505" urged '63 Dodge gets driven everywhere with one. It has a stock early B radiator and makes enough steam (pun intended) to run 11.30's.
Never moves off of 190° even in heavy traffic.
Re: 440 source water pump & housing, big block, review ??? [Re: cocamcuda] #2051021
04/10/16 01:46 PM
04/10/16 01:46 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
I was running a gmp pump and 987 hkojsing on my duster, it was running too cool. I tried a few different thermostat with no luck keeping the temp up over 170. In traffic it would creep up to about 190. I never thought I would have that problem. I started chasing a leak I thought I narrowed it down to pump leaking from the weephole. I decided if I was removing the shroud, rad, and clutch fan to change the pump I was going to do the new 440source pump, housing, and thermostat housing. The temp is more stable And now stays at 185 all the time. I can't say something was wrong with the old setup but the 440source combo is working great for me in my bb duster. They did have a problem with a restriction a while back but it has been corrected.
