499 vs 512 low deck #2050011
04/08/16 09:28 PM
04/08/16 09:28 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Starting from scratch what's your preference and why? Indy SR CNC295 will be the head. Comp. .650 solid the cam.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: 499 vs 512 low deck [Re: Eric] #2050024
04/08/16 09:49 PM
04/08/16 09:49 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
512 all the way. up More cubes, uses the 2.2 chevy rod vs the stock 2.375 journals, 1.32 compression ht. vs the 1.12 ht. of the 499.
Muscle Motors doesn't even offer the low deck 499 anymore, why bother.
Re: 499 vs 512 low deck [Re: Eric] #2050068
04/08/16 11:09 PM
04/08/16 11:09 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
512 all the way. 499 has a short piston skirt, it tends to wear faster. the 512 is longer, more stable & more choice in piston options.
Re: 499 vs 512 low deck [Re: rebel] #2050142
04/09/16 01:33 AM
04/09/16 01:33 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i can see the 512 might be the better combo in a 440 block but not a lo deck. the 4.250 stroke in a lo deck requires a shorter rod(6.535) to keep the piston at 0 deck or in the bore. seems to me the 4.150 crank with the 6.760 rod and the 1.120 pin height would be better in a lo deck or even a 6.535 rod with the 4.150 crank and a 1.350 pin height would give a better rod /stroke ratio than the 512 with the shorter rod. im no professional here but i think the longer rod is the better deal.
Re: 499 vs 512 low deck [Re: Eric] #2050162
04/09/16 02:02 AM
04/09/16 02:02 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
http://victorylibrary.com/mopar/rod-tech-c.htm
for a race engine I'd go with the 499, it seems to be a bit more efficient based on the mathematics
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 499 vs 512 low deck [Re: mopar dave] #2050165
04/09/16 02:11 AM
04/09/16 02:11 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Theoretically the shorter rod will keep the piston at TDC for less degrees of crankshaft rotation, which will be more pump gas friendly. That was one of the reasons I went with a 6.535" rod.
Re: 499 vs 512 low deck [Re: Eric] #2050171
04/09/16 02:38 AM
04/09/16 02:38 AM
In a house near you
Street Monkies Offline
In a house near you
If you don't have good enough heads for the cubic inches the longer rod is a better way to go. It just depends on the desired usage. Some are different then others.
Re: 499 vs 512 low deck [Re: Eric] #2050194
04/09/16 04:55 AM
04/09/16 04:55 AM
gregsdart Offline
gregsdart  Offline
Of all the guys running 512 low decks I haven't heard any complaints, just good power. I built a 499 with the 6.535 rods, and the piston skirt showing out the bottom of the bore bothered me, but it never gave any trouble and that motor lived a long, hard, life. I would go with the 4.25 stroke.
Re: 499 vs 512 low deck [Re: Sport440] #2050269
04/09/16 10:40 AM
04/09/16 10:40 AM
NC
440Jim Offline
440Jim  Offline
NC
I couldn't have said it better. I ran a 511 CID (4.375" bore) low deck and loved it. I do recommend a main cap aid (aluminum caps or a girdle).
Re: 499 vs 512 low deck [Re: 440Jim] #2050284
04/09/16 11:02 AM
04/09/16 11:02 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
One thing about the LD 512. The 1.54 rod ratio adds more thrust on the cylinder wall. I would make sure you have the block sonic tested and find a good one. No need to be worried about a short comp height. OEM engines now are all close to 1" comp height and go 200,000 miles. In your light car with the heads you have I would do a 470. Quicker rpms and your heads will support 470 cubes well.
Re: 499 vs 512 low deck [Re: fbs63] #2050447
04/09/16 03:47 PM
04/09/16 03:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
My first pump gas 511 stroker (4.375x 4.250 stroke w/BB Chevy rod journals sizes)400 block motor had a forged steel H beam BB Chevy type 6.800 long rod and Ross custom 22.0 cc dish pump gas pistons, that was built in and dynoed in 2002, started driving and racing that motor in 2005 and is till running today. I swapped the 4.250 stroke crank out in 2007 and put in a 4.300 stroke to move the pistons up to zero deck to get 10.28 to 1 compression after swapping out the iron 906 heads to a set of CNC ported Eddy RPM, the crankshaft swap picked the car up .2 ET(10.69 to 10.49 ET) and 3 mph(124 to 127+) with no other changes thumbs I had swap the heads the winter before and that picked it up similary also.
Re: 499 vs 512 low deck [Re: Eric] #2050568
04/09/16 07:25 PM
04/09/16 07:25 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Hey Eric, 512 and don't look back!
Re: 499 vs 512 low deck [Re: dartman366] #2050675
04/09/16 10:56 PM
04/09/16 10:56 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
looks like 511/512 hands down. Didnt really think 12 or 13 ci would make that much different. Where do you think the difference is that makes it live longer or just a better engine than the 499? Im still trying to decide too.
Re: 499 vs 512 low deck [Re: mopar dave] #2050765
04/10/16 01:45 AM
04/10/16 01:45 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I don`t know man, my 470 streeter is faster than a lot of bigger "racers" on here from what I`ve seen............ work
Re: 499 vs 512 low deck [Re: Eric] #2050785
04/10/16 02:00 AM
04/10/16 02:00 AM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
thumperdart,my 499/400 runs 5.80s-90s all motor,2950 lb car.with the 540/400 ran low 5.80s,all motor,race gas
Re: 499 vs 512 low deck [Re: dart games] #2050802
04/10/16 02:18 AM
04/10/16 02:18 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
YOU ROCK........... punkrocka What heads? Street car? My junk was at 3200+ w/issues and should be 3000-3050 lbs. hopefully now w/crap stock port rpm heads and we`ll soon see how slow it is.............. luck Went 6.20 at 111.78 w/a 1.46 60 ft. last time out in the heat on street tires now on a 29.5x10.5 slick so HOPEFULLY faster..........your stuff flys man.......... beer
Re: 499 vs 512 low deck [Re: dart games] #2050808
04/10/16 02:27 AM
04/10/16 02:27 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
What's the combo..
Re: 499 vs 512 low deck [Re: earthmover] #2050817
04/10/16 02:43 AM
04/10/16 02:43 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What's the combo..
Curious myself...........
Re: 499 vs 512 low deck [Re: Eric] #2050841
04/10/16 04:17 AM
04/10/16 04:17 AM
1.5 miles west of Jacksonburg ...
Ohio Joe Offline
Ohio Joe  Offline
This has gone 5.95 with a 470 on E85
66 Dart GT " Rat Racer"
Re: 499 vs 512 low deck [Re: Eric] #2050861
04/10/16 07:32 AM
04/10/16 07:32 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Gone 5.95 with a 455 on avgas.
