499 vs 512 low deck
#2050011
04/08/16 09:28 PM
04/08/16 09:28 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Starting from scratch what's your preference and why? Indy SR CNC295 will be the head. Comp. .650 solid the cam.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: 499 vs 512 low deck
[Re: Eric]
#2050024
04/08/16 09:49 PM
04/08/16 09:49 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
512 all the way. More cubes, uses the 2.2 chevy rod vs the stock 2.375 journals, 1.32 compression ht. vs the 1.12 ht. of the 499. Muscle Motors doesn't even offer the low deck 499 anymore, why bother.
[Re: Eric]
#2050162
04/09/16 02:02 AM
04/09/16 02:02 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
http://victorylibrary.com/mopar/rod-tech-c.htmfor a race engine I'd go with the 499, it seems to be a bit more efficient based on the mathematics
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: mopar dave]
#2050165
04/09/16 02:11 AM
04/09/16 02:11 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
i can see the 512 might be the better combo in a 440 block but not a lo deck. the 4.250 stroke in a lo deck requires a shorter rod(6.535) to keep the piston at 0 deck or in the bore. seems to me the 4.150 crank with the 6.760 rod and the 1.120 pin height would be better in a lo deck or even a 6.535 rod with the 4.150 crank and a 1.350 pin height would give a better rod /stroke ratio than the 512 with the shorter rod. im no professional here but i think the longer rod is the better deal. Theoretically the shorter rod will keep the piston at TDC for less degrees of crankshaft rotation, which will be more pump gas friendly. That was one of the reasons I went with a 6.535" rod.
[Re: Eric]
#2050194
04/09/16 04:55 AM
04/09/16 04:55 AM
Posts: 10,007 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Of all the guys running 512 low decks I haven't heard any complaints, just good power. I built a 499 with the 6.535 rods, and the piston skirt showing out the bottom of the bore bothered me, but it never gave any trouble and that motor lived a long, hard, life. I would go with the 4.25 stroke.
[Re: Sport440]
#2050269
04/09/16 10:40 AM
04/09/16 10:40 AM
Posts: 16,928 NC
440Jim
NC
512 all the way. More cubes, uses the 2.2 chevy rod vs the stock 2.375 journals, 1.32 compression ht. vs the 1.12 ht. of the 499. I couldn't have said it better. I ran a 511 CID (4.375" bore) low deck and loved it. I do recommend a main cap aid (aluminum caps or a girdle).
[Re: 440Jim]
#2050284
04/09/16 11:02 AM
04/09/16 11:02 AM
Posts: 1,839 NW Indiana
fbs63
NW Indiana
One thing about the LD 512. The 1.54 rod ratio adds more thrust on the cylinder wall. I would make sure you have the block sonic tested and find a good one. No need to be worried about a short comp height. OEM engines now are all close to 1" comp height and go 200,000 miles. In your light car with the heads you have I would do a 470. Quicker rpms and your heads will support 470 cubes well.
[Re: fbs63]
#2050447
04/09/16 03:47 PM
04/09/16 03:47 PM
Posts: 43,198 Bend,OR USA
Cab_Burge
My first pump gas 511 stroker (4.375x 4.250 stroke w/BB Chevy rod journals sizes)400 block motor had a forged steel H beam BB Chevy type 6.800 long rod and Ross custom 22.0 cc dish pump gas pistons, that was built in and dynoed in 2002, started driving and racing that motor in 2005 and is till running today. I swapped the 4.250 stroke crank out in 2007 and put in a 4.300 stroke to move the pistons up to zero deck to get 10.28 to 1 compression after swapping out the iron 906 heads to a set of CNC ported Eddy RPM, the crankshaft swap picked the car up .2 ET(10.69 to 10.49 ET) and 3 mph(124 to 127+) with no other changes I had swap the heads the winter before and that picked it up similary also.
[Re: Eric]
#2050568
04/09/16 07:25 PM
04/09/16 07:25 PM
dartman366
Mt. Vernon, Ohio
Hey Eric, 512 and don't look back!
[Re: mopar dave]
#2050765
04/10/16 01:45 AM
04/10/16 01:45 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I don`t know man, my 470 streeter is faster than a lot of bigger "racers" on here from what I`ve seen............
[Re: dart games]
#2050802
04/10/16 02:18 AM
04/10/16 02:18 AM
Thumperdart
State of confusion
thumperdart,my 499/400 runs 5.80s-90s all motor,2950 lb car.with the 540/400 ran low 5.80s,all motor,race gas YOU ROCK........... What heads? Street car? My junk was at 3200+ w/issues and should be 3000-3050 lbs. hopefully now w/crap stock port rpm heads and we`ll soon see how slow it is.............. Went 6.20 at 111.78 w/a 1.46 60 ft. last time out in the heat on street tires now on a 29.5x10.5 slick so HOPEFULLY faster..........your stuff flys man..........
[Re: dart games]
#2050808
04/10/16 02:27 AM
04/10/16 02:27 AM
Posts: 2,449 nc
earthmover
nc
thumperdart,my 499/400 runs 5.80s-90s all motor,2950 lb car.with the 540/400 ran low 5.80s,all motor,race gas What's the combo..
[Re: earthmover]
#2050817
04/10/16 02:43 AM
04/10/16 02:43 AM
Thumperdart
State of confusion
thumperdart,my 499/400 runs 5.80s-90s all motor,2950 lb car.with the 540/400 ran low 5.80s,all motor,race gas What's the combo.. Curious myself...........
[Re: Eric]
#2050861
04/10/16 07:32 AM
04/10/16 07:32 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Gone 5.95 with a 455 on avgas.
