Re: Stroker cranks available for the 400B block
[Re: Eric]
#2049154
04/07/16 08:02 PM
04/07/16 08:02 PM
Posts: 3,210 robin hood country
deaks
robin hood country
The 4.15 piston is only 468g though. Are you using the Mahle pistons? I'm using the 99497 ross pistons Eric and sorry but i got it wrong they're 486g but they're still the lightest of all the mopar BB pistons on their web page. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: mopar dave]
#2049535
04/08/16 10:28 AM
04/08/16 10:28 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
i looked at those too. I was told may not be a good choice for a street/strip deal. Strip only?
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: mopar dave]
#2049705
04/08/16 02:27 PM
04/08/16 02:27 PM
deaks
robin hood country
My ross pistons, 1.12 ch.
[Re: mopar dave]
#2049795
04/08/16 04:10 PM
04/08/16 04:10 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
Off the shelf dish nope. Just custom order. Ross 99497 is 10.5.
When it takes more than a sweet mullet to prove you rule at the trailer park..
[Re: mopar dave]
#2049808
04/08/16 04:23 PM
04/08/16 04:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Do you know if ross makes a dish piston in same specs? my compression will be alittle high at 11.6 with the flat top. Have you looked at Diamond... if they have the piston for the bore you can have them dished for $35-$40 for the set
[Re: mopar dave]
#2049849
04/08/16 05:05 PM
04/08/16 05:05 PM
MR_P_BODY
yes diamond has one as well. Dont know the weight or ring size yet. They are more money for the diamond vs the mahle. Not if they wont had your dish.. you need to look at big picture
[Re: mopar dave]
#2049860
04/08/16 05:23 PM
04/08/16 05:23 PM
MR_P_BODY
mike the dish sizes are -12.5 what i need -20 and -24. Glad im finding more options. On my 416.. I used their flat top pistons and had them add a 22cc dish to give me my compression of 10.4 with a .039 gasket.. that cost me $35 for the set.. a lot of companies wont do anything and just say... custom pistons... and if they are a few grams heavier big deal.. your not gonna turn high revs
[Re: mopar dave]
#2049868
04/08/16 05:32 PM
04/08/16 05:32 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
I have a set of new , never used Ross pistons with a 17cc dish, I believe they would work out to around 10.2-1 compression with the edlrobrock heads I used. .30 for a 400ci, .55 over for 440ci. if intrested
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
