Re: How large of a cam with 4.75 crank in standard cam block?
[Re: TT5 Valiant]
#2050433
04/09/16 03:17 PM
04/09/16 03:17 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
.560 lobe 55mm cam in this 4.75" stroke standard cam Oliver rodded motor.....
[Re: boatracer572]
#2050550
04/09/16 06:39 PM
04/09/16 06:39 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
.560 lobe 55mm cam in this 4.75" stroke standard cam Oliver rodded motor..... Very nice! 2.2" crank pin I assume? Did you have to grind on the Olivers? I have heard that they are slimmer on the big end.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2050692
04/09/16 11:20 PM
04/09/16 11:20 PM
boatracer572
San Jose Ca.
Yes, 2.200" rod journals, took about .030"of materal off the rod by the bolts on 4 rod journals.....yes they are slimmer than an aluminum grp rod by only a little bit...
