How large of a cam with 4.75 crank in standard cam block? #2049400
04/08/16 12:59 AM
04/08/16 12:59 AM
Nebraska
TT5 Valiant Offline OP
Nebraska
I have a 4.5 stroke and a 4.75 stroke Callies crank but would like to build the 4.75. Both cranks have 2.200 journals. This will be a nitrous deal with a 2 speed 400 1.48 or a 1.58 glide with 315 pro drag radials. The heads are B1mc with a fogger flowed by Kevin Neil.
1. How large of a nitrous grid cam will fit in a standard cam location (already have) world cast iron block with a 4.75 stroke with 2.200 journals and steel Oliver rods?
2. Is the torque from the 4.75 over a 4.5 stroke worth the extra work?
Just wondering if it would make a difference from the 330' to the 1/8th?
Re: How large of a cam with 4.75 crank in standard cam block? [Re: TT5 Valiant] #2049474
04/08/16 07:46 AM
04/08/16 07:46 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
My 605 runs a .767/.676 288/292@.050 on a 113C. I've got .060 lobe to rod clearance. I'm sure you can run something bigger. My 'street' motor makes 818ftlbs, I'd say the extra stroke is worth it.Dave
Re: How large of a cam with 4.75 crank in standard cam block? [Re: TT5 Valiant] #2049480
04/08/16 08:18 AM
04/08/16 08:18 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Clearance also depends on the base circle of the lobe and what rods are in it.
Doug
Re: How large of a cam with 4.75 crank in standard cam block? [Re: TT5 Valiant] #2050433
04/09/16 03:17 PM
04/09/16 03:17 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
.560 lobe 55mm cam in this 4.75" stroke standard cam Oliver rodded motor.....
Re: How large of a cam with 4.75 crank in standard cam block? [Re: boatracer572] #2050550
04/09/16 06:39 PM
04/09/16 06:39 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Very nice!
2.2" crank pin I assume? Did you have to grind on the Olivers? I have heard that they are slimmer on the big end.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: How large of a cam with 4.75 crank in standard cam block? [Re: Hemi_Joel] #2050692
04/09/16 11:20 PM
04/09/16 11:20 PM
San Jose Ca.
San Jose Ca.
Yes, 2.200" rod journals, took about .030"of materal off the rod by the bolts on 4 rod journals.....yes they are slimmer than an aluminum grp rod by only a little bit...
