Re: Billet Main Cap Question, Part 2
[Re: The Shadow]
#2049585
04/08/16 11:48 AM
04/08/16 11:48 AM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Guess you guys have never taken out keith black main caps. They have tapped holes for a slide hammer. They fit that tight ...that was my first thought.
[Re: Moparguy383]
#2049599
04/08/16 12:08 PM
04/08/16 12:08 PM
Posts: 610 Boise
Moparteacher
Boise
If they don't fit tight then you have a problem. As stated, they are an interference fit into the block. Do not remove material from the side with a belt sander or any other tool. Chamfer the corners only. A flat file works fine.
[Re: Moparguy383]
#2049603
04/08/16 12:16 PM
04/08/16 12:16 PM
Posts: 75,089 A Banana Republic near you.
JohnRR
I have been trying to get these 440source billet main caps to go back in the block and just can't seem to make them. I have tried everything I can think of. Called 440source to ask if it is normal and was told by whoever was on the phone to "touch the sides with a belt sander". If I do that, wouldn't I take the chance of getting the caps out of center with the crank? Do I need to take these to the machinist along with the thrust bearing cap? (I asked about that problem the other day.) What do you guys think? They are supposed to fit tight , if they just drop in then that is not good, but you should be able to draw them in with the bolts fairly easily ... as mentioned measure the cap and measure the block ... That said did the person really tell you to touch the sides with a belt sander ??? ..
[Re: JohnRR]
#2049606
04/08/16 12:22 PM
04/08/16 12:22 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Look at the top picture guys and you will see the issue. The caps already have a bevel on them but he has the right side way lower than the left side. The caps MUST be installed squarely.
[Re: JohnRR]
#2049691
04/08/16 02:09 PM
04/08/16 02:09 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
John , the caps look fairly level across the block to me ? You may be right but owning a set years ago I know they are tight as are my keith blacks. I had a set on my 500 inch engine that ran 275 passes running 8.60's. No block fill, no girdle, but went I tore it down the block was cracked up through the usual place. No warning no water leakage just cracked. Better than stock? YES. Better than aluminium? NO WAY.
[Re: Moparguy383]
#2049793
04/08/16 04:06 PM
04/08/16 04:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I would draw file it a couple of strokes with a fine file so you can keep it level.. both sides then test it... I would never hit them on a belt sander
[Re: MR_P_BODY]
#2049824
04/08/16 04:42 PM
04/08/16 04:42 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Guys the thing to remember here is this engine had these caps on already when it was line bored. They fit then and they should fit now. Leave the file were it belongs, in the tool box. Chamfer maybe, side of cap absolutely not. If they needed it the machine shop would have done it before the line bore
