Page 1 of 4 1 2 3 4
Billet Main Cap Question, Part 2 #2049249
04/07/16 09:56 PM
04/07/16 09:56 PM
Cumberland, MD
Moparguy383 Offline OP
Cumberland, MD
I have been trying to get these 440source billet main caps to go back in the block and just can't seem to make them. I have tried everything I can think of. Called 440source to ask if it is normal and was told by whoever was on the phone to "touch the sides with a belt sander". If I do that, wouldn't I take the chance of getting the caps out of center with the crank? Do I need to take these to the machinist along with the thrust bearing cap? (I asked about that problem the other day.) What do you guys think?
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049254
04/07/16 10:02 PM
04/07/16 10:02 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
New caps have to b line bored anyhow. Let ur machinist fit them.
Re: Billet Main Cap Question, Part 2 [Re: rickraw] #2049275
04/07/16 10:30 PM
04/07/16 10:30 PM
Cumberland, MD
Cumberland, MD
These have been line bored. When I started getting the block ready for assembly the caps were very hard to remove from the block. So hard, I had to remove the studs and take a dead blow hammer and smack them back and forth (forward and backward) about 6-8 times each before I could pull them out with my hand. I don't know how the machinist got them in the block.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049289
04/07/16 10:43 PM
04/07/16 10:43 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Wow. I bought the same caps for my 400 block.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049294
04/07/16 10:53 PM
04/07/16 10:53 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Is there any metal transfer on the block or cap? I had the same issue yrs ago. I beveled the edge of the cap slightly & tapped them in. They should fit tight.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049297
04/07/16 11:02 PM
04/07/16 11:02 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Dont touch them if they were fit that way at the machine shop.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049315
04/07/16 11:23 PM
04/07/16 11:23 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
File a slight chamfer on both the block and the cap.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049391
04/08/16 12:44 AM
04/08/16 12:44 AM
I would take them back to the machine shop that fitted those caps and ask them to fix it so you can install and remove them safely twocents It sounds like to me that they have the bottom of those caps to wide, maybe they chilled them for a short while before installing them confused
Re: Billet Main Cap Question, Part 2 [Re: Cab_Burge] #2049510
04/08/16 09:47 AM
04/08/16 09:47 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
They should fit tight in the registers. Do you have the ability to measure the fit? They should be .001-.002 interference. As stated chamfer the leading edge with a file. Just enough to lead it in.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049521
04/08/16 10:13 AM
04/08/16 10:13 AM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Guess you guys have never taken out keith black main caps.
They have tapped holes for a slide hammer. They fit that tight
Re: Billet Main Cap Question, Part 2 [Re: The Shadow] #2049585
04/08/16 11:48 AM
04/08/16 11:48 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...that was my first thought.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049599
04/08/16 12:08 PM
04/08/16 12:08 PM
Boise
Moparteacher Offline
Boise
If they don't fit tight then you have a problem. As stated, they are an interference fit into the block. Do not remove material from the side with a belt sander or any other tool. Chamfer the corners only. A flat file works fine.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049603
04/08/16 12:16 PM
04/08/16 12:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
They are supposed to fit tight , if they just drop in then that is not good, but you should be able to draw them in with the bolts fairly easily ... as mentioned measure the cap and measure the block ...
That said did the person really tell you to touch the sides with a belt sander ??? .. laugh2
Re: Billet Main Cap Question, Part 2 [Re: JohnRR] #2049606
04/08/16 12:22 PM
04/08/16 12:22 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Look at the top picture guys and you will see the issue. The caps already have a bevel on them but he has the right side way lower than the left side. The caps MUST be installed squarely.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049664
04/08/16 01:20 PM
04/08/16 01:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
John , the caps look fairly level across the block to me ?
Re: Billet Main Cap Question, Part 2 [Re: JohnRR] #2049691
04/08/16 02:09 PM
04/08/16 02:09 PM
PA.
"Little"John
"Little"John
PA.
You may be right but owning a set years ago I know they are tight as are my keith blacks. I had a set on my 500 inch engine that ran 275 passes running 8.60's. No block fill, no girdle, but went I tore it down the block was cracked up through the usual place. No warning no water leakage just cracked. Better than stock? YES. Better than aluminium? NO WAY.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Billet Main Cap Question, Part 2 [Re: pittsburghracer] #2049772
04/08/16 03:41 PM
04/08/16 03:41 PM
Cumberland, MD
Cumberland, MD
Yes I was told to use a belt sander. And yes I know the caps must be put in square to the block. I will do some measuring tomorrow when I get to the shop. Thanks.
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049790
04/08/16 04:04 PM
04/08/16 04:04 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
Do not use a belt sander. worst idea ever. if anything chamfer the top edge of the block interface with a file and that's it. tight is not a bad thing. if your worried about it, have your machine shop drill and tap some holes in the top of the caps for a slide hammer.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Billet Main Cap Question, Part 2 [Re: Moparguy383] #2049793
04/08/16 04:06 PM
04/08/16 04:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would draw file it a couple of strokes with a
fine file so you can keep it level.. both sides
then test it... I would never hit them on a belt
sander
wave
Re: Billet Main Cap Question, Part 2 [Re: MR_P_BODY] #2049824
04/08/16 04:42 PM
04/08/16 04:42 PM
PA.
"Little"John
"Little"John
PA.
Guys the thing to remember here is this engine had these caps on already when it was line bored. They fit then and they should fit now. Leave the file were it belongs, in the tool box. Chamfer maybe, side of cap absolutely not. If they needed it the machine shop would have done it before the line bore
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Page 1 of 4 1 2 3 4
