Re: Push Button 727 leaks through cable
[Re: Tommy D]
#2048674
04/07/16 10:10 AM
04/07/16 10:10 AM
Posts: 1,796 Greer, SC
TooMany62s
Greer, SC
I had the same problem with my '62 except it was the park cable. I got mine from Imperial Services http://www.imperialservices.net/Bparts.html But it took several months and the threat of mail fraud to get it delivered. The new cable solved the problem. I think the quality of the Imperial Services stuff is very good. Again, if you can get them to deliver. Be very cautious. If you know someone in Michigan maybe you can get them to go to Imperial and pick one up for you??
[Re: Tommy D]
#2048949
04/07/16 04:34 PM
04/07/16 04:34 PM
Posts: 3,916 usa
lewtot184
usa
[Re: lewtot184]
#2049000
04/07/16 05:36 PM
04/07/16 05:36 PM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
I had the cable drop onto the header melted down to the cable core. I found a hose with the center larger then the cables diameter and used RTV and slit hose to get it around the housing after it cured no leaks.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: Tommy D]
#2049148
04/07/16 07:55 PM
04/07/16 07:55 PM
Posts: 25,881 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Fluid leaks from inside the speedo cable are caused by an often overlooked seal inside the speedo pinion gear. The only lube inside the cable housing should be the cable core grease.
[Re: John_Kunkel]
#2049166
04/07/16 08:12 PM
04/07/16 08:12 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Fluid leaks from inside the speedo cable are caused by an often overlooked seal inside the speedo pinion gear. The only lube inside the cable housing should be the cable core grease. SHIFTERcable
[Re: Supercuda]
#2049188
04/07/16 08:38 PM
04/07/16 08:38 PM
John_Kunkel
Rio Linda, CA
OOPS!! Learn to read Kunkel.
[Re: Tommy D]
#2049409
04/08/16 01:13 AM
04/08/16 01:13 AM
Posts: 1,096 Australia
ozymaxwedge
Australia
Right, now that is sorted lets see your 63 !!!!
1963 Plymouth Max Wedge 1971 Barracuda
[Re: TooMany62s]
#2149312
09/07/16 12:52 AM
09/07/16 12:52 AM
Posts: 1,607 Pgh, PA
Bull1tt
Pgh, PA
I had the same problem with my '62 except it was the park cable. I got mine from Imperial Services http://www.imperialservices.net/Bparts.html But it took several months and the threat of mail fraud to get it delivered. The new cable solved the problem. I think the quality of the Imperial Services stuff is very good. Again, if you can get them to deliver. Be very cautious. If you know someone in Michigan maybe you can get them to go to Imperial and pick one up for you?? DON'T DO IT! Steve Charette who now owns Imperial Services still has $410 of my customers money for over one year, doesn't answer the phone, and will only BS you into sending him money. He's a dirtbag and a thief! Still waiting on 'parts' to finish a ratio adapter.... one of my fav quotes from this idiot was... 'How can I finish your part when I have to talk to you on the phone?' He's a real jerk.
