Page 3 of 4 1 2 3 4
Re: Stroker cranks available for the 400B block [Re: Eric] #2049154
04/07/16 08:02 PM
04/07/16 08:02 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Originally Posted By Eric
Originally Posted By deaks
The 4.15 piston is only 468g though.
Are you using the Mahle pistons?
I'm using the 99497 ross pistons Eric and sorry but i got it wrong they're 486g but they're still the lightest of all the mopar BB pistons on their web page.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049535
04/08/16 10:28 AM
04/08/16 10:28 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
Originally Posted By mopar dave
i looked at those too. I was told may not be a good choice for a street/strip deal.
Strip only?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Stroker cranks available for the 400B block [Re: Eric] #2049555
04/08/16 10:56 AM
04/08/16 10:56 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
i will call mahle and ask, but been told buy several builders not to run those short pistons in a street engine if ya want longevity.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049596
04/08/16 12:04 PM
04/08/16 12:04 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Have you ever looked at the piston CH on an LS motor or 3G Hemi?
CH for a 6.1 piston: 1.225
CH for LS1 piston: 1.328
Just food for thought. Personally one of the last thing I'd worry about is the 1.32 CH.
Re: Stroker cranks available for the 400B block [Re: Eric] #2049598
04/08/16 12:08 PM
04/08/16 12:08 PM
Mt Morris Michigan
Mt Morris Michigan
correction: I called mahle about the short piston on the street deal and they tell me that it is a myth that you will not get longevity out of a short piston such as their 1.120 pin height. so that changes things for my plan. i will try a 4.150/6.760/1.120 combo if i go the 499 deal. less weight and better rod stroke ratio. looks like a good combo
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049705
04/08/16 02:27 PM
04/08/16 02:27 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
My ross pistons, 1.12 ch.
best 60ft 1.36
Re: Stroker cranks available for the 400B block [Re: deaks] #2049713
04/08/16 02:41 PM
04/08/16 02:41 PM
Mt Morris Michigan
Mt Morris Michigan
i took another look at the mahle 1.120x4.375 and they weight the same as the ross. should make a nice lite combo with good rod stroker ratio.
Re: Stroker cranks available for the 400B block [Re: deaks] #2049732
04/08/16 03:04 PM
04/08/16 03:04 PM
Mt Morris Michigan
Mt Morris Michigan
Do you know if ross makes a dish piston in same specs? my compression will be alittle high at 11.6 with the flat top.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049782
04/08/16 03:54 PM
04/08/16 03:54 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I know they do/did for a 440 based 4.15 stroke 493. Mine are IIRC 34cc.
When I ordered my kit, Ross was the supplier for 440Source and that dish was a custom order. There were enough orders after mine that they became a shelf stocking piston and they (Ross) were so late delivering my pistons that I got a rebate on the custom upcharge. Don't know if they are still a shelf stock or not.
With zero deck and 84 CC RPM's my CR measured 8.97:1.
Kevin
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049795
04/08/16 04:10 PM
04/08/16 04:10 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Off the shelf dish nope. Just custom order. Ross 99497 is 10.5.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049808
04/08/16 04:23 PM
04/08/16 04:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you looked at Diamond... if they have the
piston for the bore you can have them dished for
$35-$40 for the set
wave
Re: Stroker cranks available for the 400B block [Re: MR_P_BODY] #2049845
04/08/16 05:01 PM
04/08/16 05:01 PM
Mt Morris Michigan
Mt Morris Michigan
yes diamond has one as well. Dont know the weight or ring size yet. They are more money for the diamond vs the mahle.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049849
04/08/16 05:05 PM
04/08/16 05:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not if they wont had your dish.. you need to look at
big picture
wave
Re: Stroker cranks available for the 400B block [Re: MR_P_BODY] #2049855
04/08/16 05:13 PM
04/08/16 05:13 PM
Mt Morris Michigan
Mt Morris Michigan
mike the dish sizes are -12.5 what i need -20 and -24. Glad im finding more options.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049860
04/08/16 05:23 PM
04/08/16 05:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On my 416.. I used their flat top pistons and had
them add a 22cc dish to give me my compression of
10.4 with a .039 gasket.. that cost me $35 for the
set.. a lot of companies wont do anything and just
say... custom pistons... and if they are a few grams
heavier big deal.. your not gonna turn high revs
wave
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049866
04/08/16 05:27 PM
04/08/16 05:27 PM
America
WedgeFED Offline
WedgeFED  Offline
America
Check with Icon (silvolite) they have quite a few selections. 775-882-7790
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2049868
04/08/16 05:32 PM
04/08/16 05:32 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
I have a set of new , never used Ross pistons with a 17cc dish, I believe they would work out to around 10.2-1 compression with the edlrobrock heads I used. .30 for a 400ci, .55 over for 440ci. if intrested
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Stroker cranks available for the 400B block [Re: MR_P_BODY] #2049879
04/08/16 05:47 PM
04/08/16 05:47 PM
Mt Morris Michigan
Mt Morris Michigan
thats good to know . thanks Mike
Re: Stroker cranks available for the 400B block [Re: WedgeFED] #2049881
04/08/16 05:50 PM
04/08/16 05:50 PM
Mt Morris Michigan
Mt Morris Michigan
I did look at those awhile back. Ill take another look.
Re: Stroker cranks available for the 400B block [Re: caper] #2049883
04/08/16 05:51 PM
04/08/16 05:51 PM
Mt Morris Michigan
Mt Morris Michigan
What the comp. Height and bore size?
Page 3 of 4 1 2 3 4
