Page 1 of 4 1 2 3 4
Stroker cranks available for the 400B block #2048103
04/06/16 04:49 PM
04/06/16 04:49 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I have found 3 4.150 cranks with 2.200 rod journal for the 400 block. Eagle,440source and molnar. Are there any other brands available for 400?
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048112
04/06/16 05:05 PM
04/06/16 05:05 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Ohio Crank. They will grind whatever you want.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048121
04/06/16 05:13 PM
04/06/16 05:13 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I'm in the same boat. I thought Scat made one also but it may be Mopar journal. I'm going with the Molnar myself.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Stroker cranks available for the 400B block [Re: fbs63] #2048138
04/06/16 05:37 PM
04/06/16 05:37 PM
Mt Morris Michigan
Mt Morris Michigan
ok. Ill give them a call.
Re: Stroker cranks available for the 400B block [Re: fbs63] #2048153
04/06/16 05:47 PM
04/06/16 05:47 PM
Mt Morris Michigan
Mt Morris Michigan
thats not too cost effective. They tell me $669 for the crank. $100 to turn rod journals to 2.200 and $175 to turn mains to fit 400 block. I see 440source has a light weight crank for $900. 4.250 only thou.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048164
04/06/16 05:58 PM
04/06/16 05:58 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Do Like I did and wait for a 4.15 that has a spun bearing, offset grind it to 4.25 or 4.30" with the 2.200 pins and Bob's your uncle
WIZE
In Car:
Re: Stroker cranks available for the 400B block [Re: Streetwize] #2048203
04/06/16 06:49 PM
04/06/16 06:49 PM
Mt Morris Michigan
Mt Morris Michigan
just may do that.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048208
04/06/16 06:55 PM
04/06/16 06:55 PM
AndyF Online content
AndyF  Online Content
SCAT has a variety of Mopar BB cranks in their new catalog. I went with SCAT for my last 470 engine.
Callies may or may not have low deck stroker cranks available. Just have to check to see what they have posted.
Re: Stroker cranks available for the 400B block [Re: fbs63] #2048244
04/06/16 07:52 PM
04/06/16 07:52 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Also
X2 up
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Stroker cranks available for the 400B block [Re: AndyF] #2048245
04/06/16 07:52 PM
04/06/16 07:52 PM
Mt Morris Michigan
Mt Morris Michigan
i think i only seen 2 on their site. None with chevy rod journals. Ill have to call them.
Re: Stroker cranks available for the 400B block [Re: AndyF] #2048253
04/06/16 08:03 PM
04/06/16 08:03 PM
Mt Morris Michigan
Mt Morris Michigan
just spoke with scat. They have 2 cranks for 400 block. Both with mopar rod journals. To have it turned by them it would be pricey at $1900.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048255
04/06/16 08:05 PM
04/06/16 08:05 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I thought the 440 source 4.15 crank was only the Mopar rod end size (2.375"?)
4.25" is 2.20 rod size. Just noticed they have a light weight 4.25 crank too
Re: Stroker cranks available for the 400B block [Re: 451Mopar] #2048265
04/06/16 08:16 PM
04/06/16 08:16 PM
Mt Morris Michigan
Mt Morris Michigan
yes and no. They have an ultra light 4.250 with 2.200 rod journal . if i can go that stroke i will be looking harder at it.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048295
04/06/16 08:58 PM
04/06/16 08:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The 2.2 rod size has a nice selection of bearings
Re: Stroker cranks available for the 400B block [Re: FastmOp] #2048308
04/06/16 09:13 PM
04/06/16 09:13 PM
IN
ahy Offline
ahy  Offline
IN
FWIW I am happy with my std rod journal 4.15" B engine crank. Decent rods and tri-metal bearings are readily available... mine was just freshened. I would not spend extra time or money to go 2.2" personally.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048312
04/06/16 09:19 PM
04/06/16 09:19 PM
Toronto (YYZ) Ontario
YYZ Offline
YYZ  Offline
FWIW I have a brand new Mopar Performance crank in the classifieds. American made, 3.900" stroke, 2.200" rod journals and all work done by a highly reputable crank specialist.
PM me if interested as I'm going a different direction
Re: Stroker cranks available for the 400B block [Re: YYZ] #2048369
04/06/16 10:24 PM
04/06/16 10:24 PM
Mt Morris Michigan
Mt Morris Michigan
if i were building a 470 i would be interesred but im going longer stroke. Thanks for the offer.
Re: Stroker cranks available for the 400B block [Re: FastmOp] #2048370
04/06/16 10:26 PM
04/06/16 10:26 PM
Mt Morris Michigan
Mt Morris Michigan
I ordered narrow king bearings for that 2.200 journal.
Re: Stroker cranks available for the 400B block [Re: mopar dave] #2048419
04/06/16 11:09 PM
04/06/16 11:09 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Did everyone suggest using Clevites when you ran a thread on bearings?
Re: Stroker cranks available for the 400B block [Re: rebel] #2048436
04/06/16 11:34 PM
04/06/16 11:34 PM
Mt Morris Michigan
Mt Morris Michigan
yes and i ordered clevit main bearings which are gonna need chamfering. I thought they were a narrow bearing like the kings.
Page 1 of 4 1 2 3 4
