727 rear roller support #2046883
04/05/16 04:45 AM
04/05/16 04:45 AM
Finland, Europe
Ck[FIN] Offline OP
Ck[FIN]  Offline OP
Finland, Europe
Does anybody have picture with measurements where should i put the bearing on the support so i dont kill the planets with restricted oil flow. Or do i have to make more oil passages to the support?
-1965 Valiant 9.03s 358cu.in R5P7-
Re: 727 rear roller support [Re: Ck[FIN]] #2046885
04/05/16 05:11 AM
04/05/16 05:11 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Isn't the bearing part of the support assembly?
Re: 727 rear roller support [Re: Ck[FIN]] #2046897
04/05/16 08:02 AM
04/05/16 08:02 AM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
Re: 727 rear roller support [Re: DusterW2] #2046973
04/05/16 11:33 AM
04/05/16 11:33 AM
Finland, Europe
Ck[FIN] Offline OP
Ck[FIN]  Offline OP
Finland, Europe
Thanks, found the correct info.
Re: 727 rear roller support [Re: Ck[FIN]] #2056981
04/18/16 05:41 PM
04/18/16 05:41 PM
NC
440Jim Offline
440Jim  Offline
NC
To fully rollerize the rear support, you can cut off the part that the rear drum spins upon. Using bearing B2414 and machining a spacer/bushing to press into the rear drum
