ACL main bearing B block #2045259
04/03/16 01:28 PM
04/03/16 01:28 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone here using ACL main bearing in your B block? looks like no one is making champherd main bearing for after market cranks in B engines. i prefer ACL and just curious if your using ACL's.
Re: ACL main bearing B block [Re: mopar dave] #2045292
04/03/16 01:53 PM
04/03/16 01:53 PM
British Columbia Canada
Challenger340 Offline
440 source offers a Chamfered main set from Clevitte for the B Engines, I forget the suffix ? C ? or CH ?
Nonetheless,
it appears to be coming directly from Clevitte chamfered that way, NOT an in house mod.
Better to be a "has been" than a "never was".
Re: ACL main bearing B block [Re: Challenger340] #2045300
04/03/16 02:02 PM
04/03/16 02:02 PM
Mt Morris Michigan
Mt Morris Michigan
ok, i was just on there site reading that, but according to 440sourse the main bearing offered for 400 block are narrow bearing and will work without a chamfer but you need to check them upon assembly. hughes offers the clevites chamfered as well.
Re: ACL main bearing B block [Re: Challenger340] #2045304
04/03/16 02:06 PM
04/03/16 02:06 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I thought the 4094M bearing were the hot ticket in the 2.625" main size?
Re: ACL main bearing B block [Re: Jeremiah] #2045316
04/03/16 02:12 PM
04/03/16 02:12 PM
Mt Morris Michigan
Mt Morris Michigan
that is the bearing Cab told me to use. i had very good luck with the ACL's in the small block i would like to stay with that brand if possible. if not i have no problem using the fed mogul 4094m.
Re: ACL main bearing B block [Re: Jeremiah] #2045377
04/03/16 02:48 PM
04/03/16 02:48 PM
Mt Morris Michigan
Mt Morris Michigan
wow, just read some comparisons on ACL vs King bearings. seems the ACL's are all over the place lately when measuring bearing clearance compared to King bearings which seem to be very precise in clearance bearing to bearing.
Re: ACL main bearing B block [Re: mopar dave] #2045434
04/03/16 03:32 PM
04/03/16 03:32 PM
IMO, Clevitte are no better these days, all over the map.
Tested a set of CB527HN recently against a vintage set of 15-20 yr old CB527H Bearings....
.0007" to .0008" Tighter Vertical Clrc in the same Rods.
then,
bought another set of CB527HN's from 3 years ago.... only .0003"to .0004" tighter...again, same rods.
and,
still using the vintage set as the "control" with the same rods.
My conclusion:
IMO, Clevitte Bearing overlays may be getting thicker ??
I just dunno here ?
But I recommend grinding Cranks smaller(even under lowside) to allow yourself "room" to get your Clrc.
Re: ACL main bearing B block [Re: Challenger340] #2045456
04/03/16 03:54 PM
04/03/16 03:54 PM
Mt Morris Michigan
Mt Morris Michigan
thats nice to know. looks like King doesnt offer a full groove main bearing for B block either. looks like ill be getting the recommended fed mogul/sealed power 4094M at this point. may look at the King rod and cam bearing thou.
Re: ACL main bearing B block [Re: Jeremiah] #2045490
04/03/16 04:17 PM
04/03/16 04:17 PM
Mt Morris Michigan
Mt Morris Michigan
before i order the 4094m are these the bearing for high performance use or is there a H series in these?
Re: ACL main bearing B block [Re: mopar dave] #2045515
04/03/16 04:40 PM
04/03/16 04:40 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
I'll check my notes see what I have in my lo deck 451 should have part numbers from crankshaft specialist..
Re: ACL main bearing B block [Re: mopar dave] #2045537
04/03/16 04:58 PM
04/03/16 04:58 PM
No H series bearings in Federal Mogul that I have heard or read about.These bearings,M4095 RB and M4094 B engines, where originally listed for trucks with full narrow grooves work I like and use them a lot thumbs
Re: ACL main bearing B block [Re: Cab_Burge] #2045561
04/03/16 05:29 PM
04/03/16 05:29 PM
Mt Morris Michigan
Mt Morris Michigan
ok, good enough for me.
Re: ACL main bearing B block [Re: mopar dave] #2046264
04/04/16 02:18 PM
04/04/16 02:18 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Funny , I have an eagle crank that uses out of the box main bearings, no chamfer is required ??
I would think a Molnar crank would have chamfer that didn't require hacking bearings ?
Re: ACL main bearing B block [Re: Challenger340] #2046288
04/04/16 02:50 PM
04/04/16 02:50 PM
Mt Morris Michigan
Mt Morris Michigan
yes they do but they are very expensive.
Re: ACL main bearing B block [Re: JohnRR] #2046292
04/04/16 02:54 PM
04/04/16 02:54 PM
Mt Morris Michigan
Mt Morris Michigan
that is a narrow bearing. i am now looking at getting the sp 4094m stock replacement which cab uses with good results or the clevite ms876p. i believe these are all narrow bearings. thanks
