Dakota with cop car wheels #2040897
03/29/16 01:14 AM
03/29/16 01:14 AM
Id
mopeman Offline OP
mopeman  Offline OP
Id
Anybody have a picture of an early Dakota with cop car wheels. I just bought a 1990 that has some horrible after market wheels and a spare set of the cop car wheels. Thanks!
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: Dakota with cop car wheels [Re: mopeman] #2041098
03/29/16 12:09 PM
03/29/16 12:09 PM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
There was a gen 1 Dakota around here years ago with them. IIRC, it looked a little goofy as the backspacing was wrong and they stuck out to far.
Ed
Re: Dakota with cop car wheels [Re: mopeman] #2041130
03/29/16 12:50 PM
03/29/16 12:50 PM
places
79powerwagon Offline
places
Wheels rarely stick out TOO far! wink
There should be a good dish to a wheel, unlike ALL factory Dakotas that look like toys instead of trucks. Mine had daisy wheels! Gads! How sad!
Re: Dakota with cop car wheels [Re: mopeman] #2041507
03/29/16 10:55 PM
03/29/16 10:55 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Cop car wheels will put the tires at the outer edge of the fenders, at the top of the tire. Dakota body's curve under as they go lower, you will be constantly kicking up stuff and covering the bottom 1/2 of the truck body (worse then the standard Dakota already does). I think the cop wheels look good on a Dakota. Gene
Re: Dakota with cop car wheels [Re: poorboy] #2041669
03/30/16 02:01 AM
03/30/16 02:01 AM
Id
mopeman Offline OP
mopeman  Offline OP
Id
Well they can't be as bad the wheels that are already on there. I can't believe I can't find one picture with either regular steelies or cop car rims! Anyway, I will pull one off this weekend and check the back spacing, the rims on there stick out quite a bit already and I don't like the look.
Mopar or no car
'93 W250 Ram
'68 Charger
Re: Dakota with cop car wheels [Re: mopeman] #2042068
03/30/16 04:54 PM
03/30/16 04:54 PM
Jacksonville, AR
dmckeehan Offline
dmckeehan  Offline
Jacksonville, AR
1985 Crew Cab W250 4x4 - daily driver, 5.9 magnum, carbed and distributor, A-518 and NP205
2002 3500 extended cab, 4x4, Cummins and 6 speed
1997 Ram 2500 5.9 with 35 Boggers - Mud Racer
1993 Dakota 4x4, Dana 60's front and rear - work in progress
1992 Dakota 2wd short bed, awaiting 440 swap
Re: Dakota with cop car wheels [Re: mopeman] #2042073
03/30/16 05:00 PM
03/30/16 05:00 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
there are intrepid wheels with the correct backspacing---running some 16" steelies on my 50 hudson (dakota clip).....
Re: Dakota with cop car wheels [Re: mopeman] #2042323
03/30/16 11:24 PM
03/30/16 11:24 PM
Id
mopeman Offline OP
mopeman  Offline OP
Id
Pulled the ugly wheels and they a 3 3/4 inch backspacing. So at least with the cop steel wheels it will bring them in another 1/2 inch. So I might swap the rubber and see how it looks.
Mopar or no car
'93 W250 Ram
'68 Charger
Re: Dakota with cop car wheels [Re: mopeman] #2042387
03/31/16 12:07 AM
03/31/16 12:07 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
OK, first picture, the red 93 Dakota 4x4 with the standard 15 x 6" Dakota wheels and 235-75-15 tires.
Picture 2 The black coupe is my 48 Plymouth under construction. This is a 90 Dakota 2 wd drive Dakota frame. The front wheels are standard issue 15" x 6" Dakota wheels, the rear wheels are standard rear wheel drive car 15 x 6 1/2" off an 80s 5th Ave. All the tires on the coupe are 235-75-15 radials also. You can pretty much see the difference in the offset. The cop wheels will have the same offset as the 5th Ave wheels.
I would put one of the 5th Ave wheels on the 93, but its 6 lug & the 5th Ave was 5 lug. Gene
