Re: Lifter bore bushing trouble? Help in Penna.
[Re: 70satelliteguy]
#2040616
03/28/16 07:53 PM
03/28/16 07:53 PM
fast68plymouth
So. Burlington, Vt.
I'm pretty sure that whoever shady dell(state college area)is hooked up with has a CNC block machine.
[Re: The Shadow]
#2040680
03/28/16 09:18 PM
03/28/16 09:18 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Don't think it was a problem with the cam as it has been in the motor for 7 years prior without issue. Machine shop always goes over my springs every year and the rockers are Jesel 1.7 that are only 2 years old.What should I look for that would send up red flags? Are there different types of bushings that they can replace this one with? Maybe one more durable? Mike
#2040704
03/28/16 09:35 PM
03/28/16 09:35 PM
Posts: 2,175 Duloc
The Shadow
Duloc
The bushings should be a nickle bronze or ampco 45 (trade name) Is the bushing the same colour/shade?
[Re: The Shadow]
#2041089
03/29/16 11:53 AM
03/29/16 11:53 AM
Posts: 1,301 Penna
70satelliteguy
Penna
"The bushings should be a nickle bronze or ampco 45 (trade name) Is the bushing the same colour/shade?" The bushing is bronze colored. It was much tighter when installed last year. "ordered bushings from bhj with a bigger od" Jim could you elaborate who bhi is so I could check things out with them? Mike
