Lifter bore bushing trouble? Help in Penna. #2040528
03/28/16 04:50 PM
03/28/16 04:50 PM
Penna
70satelliteguy Offline OP
Penna
I had a loose lifter bore in my Mega block last winter after 8 seasons of use and had a local shop install a bushing to fix the problem.All the other bores seem to be ok. It seemed to fix the problem(tightened it up) but I noticed that my oil pressure was a little low on the return road(10-15 lbs last year.The car ran good.
I am getting ready to put motor back in for this year and noticed that the lifter bore is loose again!!!There is obvious wear near the bottom of the bronze bushing. I am thinking that it was installed incorrectly.
Where in Central Pennsylvania can I get someone to do this correctly?
Thanks Mike
Re: Lifter bore bushing trouble? Help in Penna. [Re: 70satelliteguy] #2040564
03/28/16 05:52 PM
03/28/16 05:52 PM
kansas
farmboy Offline
farmboy  Offline
kansas
I probably done a hundred blocks, and to my knowledge, none ever loosened up. Have you checked if there was an issue with the cam, that may be causing the wear. Those bronze bushings rarely wear out.
Re: Lifter bore bushing trouble? Help in Penna. [Re: 70satelliteguy] #2040614
03/28/16 07:47 PM
03/28/16 07:47 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Isn't Barton in Pennsylvania ????
Re: Lifter bore bushing trouble? Help in Penna. [Re: 70satelliteguy] #2040616
03/28/16 07:53 PM
03/28/16 07:53 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'm pretty sure that whoever shady dell(state college area)is hooked up with has a CNC block machine.
Re: Lifter bore bushing trouble? Help in Penna. [Re: 70satelliteguy] #2040658
03/28/16 08:48 PM
03/28/16 08:48 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
You dont need to re machine to replace a bushing.
Maybe the honed it too much
Re: Lifter bore bushing trouble? Help in Penna. [Re: 70satelliteguy] #2040676
03/28/16 09:14 PM
03/28/16 09:14 PM
AndyF Offline
AndyF  Offline
I'm wondering if you don't have a problem with that particular cam lobe or cylinder. Might have something going on with the valve spring or rocker arm or such.
Re: Lifter bore bushing trouble? Help in Penna. [Re: The Shadow] #2040680
03/28/16 09:18 PM
03/28/16 09:18 PM
Penna
Penna
Don't think it was a problem with the cam as it has been in the motor for 7 years prior without issue. Machine shop always goes over my springs every year and the rockers are Jesel 1.7 that are only 2 years old.What should I look for that would send up red flags?
Are there different types of bushings that they can replace this one with? Maybe one more durable?
Mike
Re: Lifter bore bushing trouble? Help in Penna. [Re: 70satelliteguy] #2040704
03/28/16 09:35 PM
03/28/16 09:35 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
The bushings should be a nickle bronze or ampco 45 (trade name)
Is the bushing the same colour/shade?
Re: Lifter bore bushing trouble? Help in Penna. [Re: The Shadow] #2040983
03/29/16 05:20 AM
03/29/16 05:20 AM
central Pa.
71Pan Offline
71Pan  Offline
central Pa.
ober Performance Litiz Pa. Does ton of stocker a super stock work
717 626 4293
Re: Lifter bore bushing trouble? Help in Penna. [Re: 70satelliteguy] #2041057
03/29/16 10:54 AM
03/29/16 10:54 AM
wappinger falls new york
Jimi_Vignogna Offline
it may be when the lifter bore was machined the end mill could have had a burr or have been dull. i had this happen before on a chevrolet the end mill was dull and actually drilled .002" bigger so i ordered bushings from bhj with a bigger od. that engine has been is a street/strip car for 6 years no problems.
Re: Lifter bore bushing trouble? Help in Penna. [Re: The Shadow] #2041089
03/29/16 11:53 AM
03/29/16 11:53 AM
Penna
Penna
"The bushings should be a nickle bronze or ampco 45 (trade name)
Is the bushing the same colour/shade?"
The bushing is bronze colored.
It was much tighter when installed last year.
"ordered bushings from bhj with a bigger od"
Jim could you elaborate who bhi is so I could check things out with them?
Mike
