Re: 318 for drag race use
[Re: 318 racer]
#2039084
03/26/16 12:03 PM
03/26/16 12:03 PM
Posts: 7,506 Az
Crizila
Az
Goal is 10.50-10.70's in 1/4 mile. Have to be able to use 750 TQ. 8K was a guess on RPM,I was thinking 7500 actually.
Not interested in other combos..car will weigh in at 3300#.
I know it can be done,there are a few 318's running in NHRA GT classes.I know a roller cam is a must plus the usual mods..but the oiling system is what I am concerned with. 10.50's @ 3300lbs will be a stretch IMO. Go on a diet. As said, you don't have to lose your mind on oiling system mods. My sm blk sees 7K regularly with nothing more than cleaned up / smoothed passages and a HV pump, thin, full synthetic oil. What size needles / seats will you be running on that TQ? Keeping enough fuel in the bowls could be an issue.
Fastest 300
[Re: WO23Coronet]
#2039115
03/26/16 12:39 PM
03/26/16 12:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What does bushing the lifters do for oiling? Does it "save" the oil for the mains/rods since it's not bleeding past the lifters or supplying oil to the hydraulic slack adjustment in the lifters? Do you still need to drill a small hole in them to give lubrication to lifter/bushing interface? Or is splash lubrication enough to not have the lifters seize in their bores since there's no load on them? If not running PR oiling then I didnt add any hole.. the drain back gives plenty for the lifter and splash does the rest(we are taking solid rollers)
[Re: MR_P_BODY]
#2039133
03/26/16 01:25 PM
03/26/16 01:25 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
8500 every pass with 360 bored .100" over. Light pistons and aluminum rods. Tube in the block with crane rollers. We heads and Harland sharp rockers.
That's 3.58 stroke cast crank. With a 3.31" stroke steel crank with 2.25" mainss it's not even a challenge to turn that rpm. Make power at 8,000 and up with 3.910" bore and stock configuration heads. There's your challenge.
[Re: 318 racer]
#2039178
03/26/16 03:01 PM
03/26/16 03:01 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I will never understand why guys insist on reving the piss out of these engines. Why spend all the needed money on upgrades to shift that high especially when you only want to run 10.50's. My Sons 360 goes faster than that at 3200 pounds shifting at 6400 rpm and will go VERY low 10's this year with a 408 shifting at 6800 rpm.
[Re: 318 racer]
#2039189
03/26/16 03:23 PM
03/26/16 03:23 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
That's one of the reasons I'm asking all the questions...if it doesn't need to rev that high.....great! Even better! If a 318 can go 10.70's and not rev high..let me know all about it. Its so easy with a 50 dollar 360 bone-yard core. Not saying a 318 won't do it because it will but take advantage of the extra cubes. 360 bored .030 over ported Edelbrock heads 520 Racer Brown solid lift cam Diamond Pistons (or piston of your choice) 750 holly ported victor intake 11.2.1 comp (pump gas) prepped stock 360 crank K1 rods (or rod of your choice) 4.10 gears 727 with 5400-5500 stall converter. headmen 1 7/8 headers Pretty basic SIMPLE combo.
[Re: pittsburghracer]
#2039211
03/26/16 04:18 PM
03/26/16 04:18 PM
MR_P_BODY
Why is the pro stocks were turning 12K to make the power... now they turn 10.5K and they are down on power... simple.. every time the piston hits its making power.. we tend to measure in RPM (thats per minute)... more pulses = more power.. just have to build it for the rpm.. if that 360 made X amount of power and it had the right parts to rev higher it would make more power EDIT the smaller the CI you have to turn it higher to make the power... if you go out there with a 318 and turn 7500 the next guy will be turning 8500 and be quicker every time if its built for the revs
[Re: 318 racer]
#2039233
03/26/16 05:24 PM
03/26/16 05:24 PM
Posts: 4,255 Canada
WO23Coronet
Canada
Why not put a 4" arm in your 318 if your stuck on using a "318"? Give you a 392 if I remember correctly. You'd likely be buying an aftermarket crank anyway
[Re: 318 racer]
#2039262
03/26/16 06:24 PM
03/26/16 06:24 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Oh and for the record a stroker does make much more sense from an easy point of view or a budget point of view and they are more fun on the street. They just don't sound as awesome.
[Re: 318 racer]
#2039267
03/26/16 06:31 PM
03/26/16 06:31 PM
MR_P_BODY
Will you actually be class racing this... a 4" stroke would be easier.. still use your 318 block.. that would give you more torque
[Re: 318 racer]
#2039303
03/26/16 07:39 PM
03/26/16 07:39 PM
Posts: 7,506 Az
Crizila
Az
Too bad so many of these posts are trying to talk this guy ( "318 racer"!!!!! )in to something other than what he wants to do - and pretty much irrelevant to what he really wants to do. Not that I don't agree with some of the comments, but . . . . . . He doesn't want to race a 340, 360, 390, 408, 416, or a 426! His handle is 318 racer!!!!!!! READ THE OP!!
Fastest 300
[Re: Crizila]
#2039305
03/26/16 07:43 PM
03/26/16 07:43 PM
MR_P_BODY
Too bad so many of these posts are trying to talk this guy ( "318 racer"!!!!! )in to something other than what he wants to do - and pretty much irrelevant to what he really wants to do. Not that I don't agree with some of the comments, but . . . . . . He doesn't want to race a 340, 360, 390, 408, 416, or a 426! His handle is 318 racer!!!!!!! READ THE OP!! I read all of it... and I gave my suggestion for it.. but ALSO added another... its he choice what he wants to do... but I also asked if he is gonna class race this which has rules
[Re: Crizila]
#2039337
03/26/16 09:11 PM
03/26/16 09:11 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Too bad so many of these posts are trying to talk this guy ( "318 racer"!!!!! )in to something other than what he wants to do - and pretty much irrelevant to what he really wants to do. Not that I don't agree with some of the comments, but . . . . . . He doesn't want to race a 340, 360, 390, 408, 416, or a 426! His handle is (DUK)!!!!!!! READ THE OP!! Just trying to help. Sorry I won't make that mistake again and ruffle YOUR feathers.
[Re: 318 racer]
#2039338
03/26/16 09:13 PM
03/26/16 09:13 PM
HotRodDave
Kalispell Mt.
See what I meant about the thick skin!
[Re: 318 racer]
#2039340
03/26/16 09:14 PM
03/26/16 09:14 PM
Posts: 22 Georgia
318 racer
Georgia
All,
I REALLY appreciate all of the info so far.I hope there will be more info. I didnt post anywhere else,Moparts seems to have a lot of good knowledge.
If this engine works out,and does what it needs to do,then I may consider running it in class. No way could I be a record holder,but if somewhat competitive.But that thought is way way way way down the road.I'd have to upgrade my car too,and to be honest,I like bracket racing. I like combos that everyone says cant be done.
I used to race 440 Chryslers...great engines,but everyone turns their noses up at the ol' 318. I really think it can be a good engine. If it doesnt need to go high RPM,I'm good with that. I always heard you had to rev a small block.440's obviously,you dont. I just would like you guys to tell me what the best stuff is to use. I just had 2 restrictions,the heads and the carburetor.And I'd like to go 10.70's.Even the old Direct Connection "bible" has a 10 second 318 combo,but I think it's a stretch there.
[Re: Crizila]
#2039349
03/26/16 09:37 PM
03/26/16 09:37 PM
Quicktree
Too bad so many of these posts are trying to talk this guy ( "318 racer"!!!!! )in to something other than what he wants to do - and pretty much irrelevant to what he really wants to do. Not that I don't agree with some of the comments, but . . . . . . He doesn't want to race a 340, 360, 390, 408, 416, or a 426! His handle is 318 racer!!!!!!! READ THE OP!! no problem if he doesn't mind spending a small fortune to reach his goal. pretty stupid if it's not a class racer.
