Re: 318 for drag race use
[Re: 318 racer]
#2038746
03/25/16 09:10 PM
03/25/16 09:10 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Welcome to moparts, hope you got thick skin.
Lots of cam (solid roller), lots of compression and a max effort port job by a reputable shop. Those heads are a little limited in cross section and CFM but you could probably do it with enough money. 1000CFM thermoquad.
Intake, probably heavily worked super-victor.
If the goal is really 8000 you may look for an old transam destroked crank. Turn it to 2.0 rod journals and get some 6.5 inch chevy rods from a good source like carrillo. Pistons are gonna need a small dome and heads milled as short as possible to get compression without a flame front restricting dome.
Oiling is probably past the limit of a stock system and will need a few mods, get some full groove main bearings, bush the lifter holes, radius the sharp corners in the passages...
Do you got a certain ET goal? I built an engine for a guy who wanted to turn 8000 and it did (was out of breath but you could push it there) with some heavily worked w2s on a 340 (bigger bore to help breath better). He was much happier with a 6000 RPM stroker in the end.
[Re: 318 racer]
#2038754
03/25/16 09:27 PM
03/25/16 09:27 PM
Posts: 4,457 Washington
madscientist
Washington
Only if the block has an X or an R on it. Otherwise skip it.
The head you want to use won't support 8k even on 318 inches.
Valve train will kill you.
Oiling is an issue. You must correct the oil timing. Otherwise, it will be spitting the chitlits out on a regular basis.
[Re: 318 racer]
#2038756
03/25/16 09:31 PM
03/25/16 09:31 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Welcome... what do you figure for ET or hp goal.. I'm one of the few on here that will rev a SB.. a big bore will help.. I've never used the heads you want to use.. all my stuff is W series heads.. W-2 ,W-5 and W-9.. even my W-2s I was turning 8200 rpm but they flowed 305+... whats the package you are planning on
[Re: 318 racer]
#2038761
03/25/16 09:36 PM
03/25/16 09:36 PM
crabman173
crabman173
What is performance goal?? Very very few small blocks need or will be happy at 8000 just no need Stock Edelbrocks are held back by pushrod pinch that is why Indy relocated the shaft position using big block rockers thus giving correct offset--opening up the pinch and allowing bigger springs which are the real issue with that head and that kind of RPM A high winding 318 may be fun but would still be outclassed by a normal 408 turning 6500 1/8th or 1/4? Think of the 340 W2 combos they ran back in the day with tunnel rams and 8000 plus They ate bearings -- you should be able to have MUCH lighter parts than they had thus helping a ton--The oil pan they used was DEEP--like 12 qt deep and used the old Milodon cover and two pick ups--all band aids you really need dry sump to make it live--bushed lifter bores a must and for that expense right there you can do the stroker Main thing that will keep you busy is head gaskets--That kind of RPM requires a cam that needs mucho compression--and big compression on a 10 head bolt small block keeps you busy--I always ran clear tube from the evacs so when I saw vapor in the tube I knew it was head gasket time before it failed--I had good luck with more rod bearing clearance in high RPM small blocks Belt drive--high dollar lifters--etc Valve springs are the real limiting factor--with that goal bigger is really better and I would think titanium valves an absolute must-- All this if you want to make seriuos power--if you just want to glance off 8000 then no big deal
[Re: 318 racer]
#2038765
03/25/16 09:41 PM
03/25/16 09:41 PM
crabman173
crabman173
I would never try that combo--way too many shortcomings and just a $$$$$$$$ pit
[Re: ]
#2038770
03/25/16 09:47 PM
03/25/16 09:47 PM
MR_P_BODY
I would never try that combo--way too many shortcomings and just a $$$$$$$$ pit I dont know who your talking to with this.. qoute if needed
[Re: MR_P_BODY]
#2038783
03/25/16 10:04 PM
03/25/16 10:04 PM
MR_P_BODY
I've been racing stock 340 blocks and a R-block for a long time... all of them turned 8200 except the stock viper rod engine.. that one let go at 8200 rpm after about a year racing every weekend.. its all about flow and the balance of the engine.. my 395ci is still running strong and it turned 8200 every pass... my other stuff has gone higher
[Re: 318 racer]
#2038826
03/25/16 11:05 PM
03/25/16 11:05 PM
Posts: 7,506 Az
Crizila
Az
First post here.. I'd like to build a 318 for drag race use. Max 8000 rpm.Would like to know what you guys would use for all parts for the build. However there are 2 items the engine must use...
Edelbrock cylinder heads
ThermoQuad carburetor.
No it's not a NHRA/IHRA engine for class racing,but would like to build along those parameters.
Cam,intake header size,crank,rods pistons,oiling system etc... what would you use?
Engine will be in a A-body Duster. You willed need to do some major port work on the heads ( 300 cfm range ). With some mods, the carb will work ( even the 800 ). I'd go with a Victor 340 manifold, 1 7/8" - 2" on the primary size for the headers, Quality rotating assembly ( Forged crank, H beams, Diamond pistons ). Oiling mods as suggested for sure. Solid roller ( custom grind )from Comp, etc. I like ThermoQuads too. Have fun.
Fastest 300
[Re: 318 racer]
#2038875
03/26/16 12:05 AM
03/26/16 12:05 AM
MR_P_BODY
Goal is 10.50-10.70's in 1/4 mile. Have to be able to use 750 TQ. 8K was a guess on RPM,I was thinking 7500 actually.
Not interested in other combos..car will weigh in at 3300#.
I know it can be done,there are a few 318's running in NHRA GT classes.I know a roller cam is a must plus the usual mods..but the oiling system is what I am concerned with. Drill out all the oil passages to the mains to 9/32.. I think thats the drill and blend the pump so it flows better, use a high flow pump and .003/.003 on the clearances..dont use a heavy oil.. I like to set my oil pressure at 18 psi on the end of a run at idle hot... a goodvalve train is a must.. I use TD.. also I like to turn down the crank counter weight and move the weight in closer to the centerline... H-beam rods and light pistons EDIT I forgot... I bush the lifter bores
[Re: Quicktree]
#2039040
03/26/16 10:14 AM
03/26/16 10:14 AM
Posts: 739 Florida
408Dust
now tell him how much thats going to cost better have deep pocket Sorry forgot about that, a truck load... But it's a blast for sure.
[Re: 318 racer]
#2039081
03/26/16 11:56 AM
03/26/16 11:56 AM
Posts: 4,206 New York
polyspheric
New York
Not to be the wet blanket, but you're bringing a sharp stick to a gun fight.
Boffin Emeritus
