down legg or annular boosters #2037537
03/24/16 12:06 AM
03/24/16 12:06 AM
TN
SCATPACK 1 Offline OP
TN
Which one and why?
I understand the difference in them, design wise. But what are the performance differences? When will you use the annular boosters as opposed to the downleg booster? Which would work better on a road course or street? Which is better for big inch engines?
Jerry
Old Geezer Racing
Re: down legg or annular boosters [Re: SCATPACK 1] #2037600
03/24/16 01:40 AM
03/24/16 01:40 AM
AndyF Offline
AndyF  Offline
This is one of the better articles on the subject:
http://www.hotrod.com/how-to/engine/116-0508-carburetor-showdown/
Re: down legg or annular boosters [Re: SCATPACK 1] #2037624
03/24/16 02:51 AM
03/24/16 02:51 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I am running annualars on my primaries on the hemi for crisp off idle response and downlegs on the secondary's for overall air flow in my Quickfuel 770's. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: down legg or annular boosters [Re: astjp2] #2037639
03/24/16 05:38 AM
03/24/16 05:38 AM
Graz, Austria
DGS Offline
DGS  Offline
Graz, Austria
I wanted to do the same but was told that I will get problems with fuel distribution between the different cylinders (fuel droplet size is different).
Re: down legg or annular boosters [Re: SCATPACK 1] #2037700
03/24/16 11:49 AM
03/24/16 11:49 AM
Mark Whitener Offline
Everything I build gets an annular booster as long as the carb size isn't restrictive. With annular boosters it allows you to use a larger carb and still get as good or better atomization, better distribution of fuel. That means power. And with some modified booster inserts airflow loss can be kept to a minimum.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: down legg or annular boosters [Re: SCATPACK 1] #2037713
03/24/16 12:05 PM
03/24/16 12:05 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a 1050 Dominator with annulars on the street on my 440.Idle isnt great at times but it does have good response.Rocky
Chrysler Firepower
Re: down legg or annular boosters [Re: therocks] #2037785
03/24/16 02:23 PM
03/24/16 02:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You need to work on the idle circuit then...........idle bleeds and ifr`s and then tweak the idle mixture screws to fine tune.........
Re: down legg or annular boosters [Re: Thumperdart] #2037860
03/24/16 04:23 PM
03/24/16 04:23 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
We are testing two 4150 style Quickfuel 1050's on my 511. They are identical other than the boosters. I've had good luck with annular boosters.
Re: down legg or annular boosters [Re: SCATPACK 1] #2038137
03/24/16 11:19 PM
03/24/16 11:19 PM
TN
TN
Good info guys. Thanks for the link Andy.
Old Geezer Racing
Re: down legg or annular boosters [Re: SCATPACK 1] #2038159
03/24/16 11:51 PM
03/24/16 11:51 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Yes, that's a good article. This might be of interest.
http://www.hotrod.com/how-to/engine/0511phr-carburetor-boosters-tech/
Yeah, it's got a smallblock.
Re: down legg or annular boosters [Re: astjp2] #2047353
04/05/16 08:17 PM
04/05/16 08:17 PM
Earth
Rob C Offline
Rob C  Offline
Earth
I can see where that makes sense and even more so after reading the article.
Re: down legg or annular boosters [Re: DGS] #2047359
04/05/16 08:23 PM
04/05/16 08:23 PM
Earth
Rob C Offline
Rob C  Offline
Earth
I wouldn't believe that. Reason being is the need and how the engine reacts to the fuel at different engine speeds and loads. A fine mist for low speed and cruise conditions and bigger droplets of fuel for high load/speed (AKA - W.O.T.)
Since driving on the primary side is probably better with the angular booster and the WOT works best with bigger droplets, the combo of boosters are a good theory to try out.
Jetting is key to everything.
Re: down legg or annular boosters [Re: Rob C] #2047373
04/05/16 08:48 PM
04/05/16 08:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
EVERYTHING being correct is the key............jetting is a good part of the fuel available and emulsion, angle channel size, booster type and outlet size, bleed size etc. all contribute to a "Clean n Mean" working carb............
Re: down legg or annular boosters [Re: Mark Whitener] #2047932
04/06/16 01:44 PM
04/06/16 01:44 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Mark would you explain modified booster inserts please?
Thanks,
Don
Re: down legg or annular boosters [Re: SCATPACK 1] #2047955
04/06/16 02:07 PM
04/06/16 02:07 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i think he Mark was implying, if you use a booster insert like the red ones in the first post vs something like this fat holley annular booster, then you lose less of the cfm capability of the carb...
Re: down legg or annular boosters [Re: SCATPACK 1] #2048016
04/06/16 03:17 PM
04/06/16 03:17 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I like the response of the annular boosters, but they do lower the CFM rating of the carb (given same bore size.)
