down legg or annular boosters
#2037537
03/24/16 12:06 AM
03/24/16 12:06 AM
Posts: 1,505 TN
SCATPACK 1
TN
Which one and why? I understand the difference in them, design wise. But what are the performance differences? When will you use the annular boosters as opposed to the downleg booster? Which would work better on a road course or street? Which is better for big inch engines? Jerry
Old Geezer Racing
Re: down legg or annular boosters
[Re: SCATPACK 1]
#2037624
03/24/16 02:51 AM
03/24/16 02:51 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I am running annualars on my primaries on the hemi for crisp off idle response and downlegs on the secondary's for overall air flow in my Quickfuel 770's. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2037639
03/24/16 05:38 AM
03/24/16 05:38 AM
Posts: 637 Graz, Austria
DGS
Graz, Austria
I am running annualars on my primaries on the hemi for crisp off idle response and downlegs on the secondary's for overall air flow in my Quickfuel 770's. Tim I wanted to do the same but was told that I will get problems with fuel distribution between the different cylinders (fuel droplet size is different).
[Re: SCATPACK 1]
#2037700
03/24/16 11:49 AM
03/24/16 11:49 AM
Posts: 304 Florida
Mark Whitener
Everything I build gets an annular booster as long as the carb size isn't restrictive. With annular boosters it allows you to use a larger carb and still get as good or better atomization, better distribution of fuel. That means power. And with some modified booster inserts airflow loss can be kept to a minimum.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: SCATPACK 1]
#2037713
03/24/16 12:05 PM
03/24/16 12:05 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
I run a 1050 Dominator with annulars on the street on my 440.Idle isnt great at times but it does have good response.Rocky
Chrysler Firepower
[Re: therocks]
#2037785
03/24/16 02:23 PM
03/24/16 02:23 PM
Thumperdart
State of confusion
I run a 1050 Dominator with annulars on the street on my 440.Idle isnt great at times but it does have good response.Rocky You need to work on the idle circuit then...........idle bleeds and ifr`s and then tweak the idle mixture screws to fine tune.........
[Re: SCATPACK 1]
#2038137
03/24/16 11:19 PM
03/24/16 11:19 PM
Posts: 1,505 TN
SCATPACK 1
TN
Good info guys. Thanks for the link Andy.
Old Geezer Racing
[Re: astjp2]
#2047353
04/05/16 08:17 PM
04/05/16 08:17 PM
Posts: 792 Earth
Rob C
Earth
I am running annualars on my primaries on the hemi for crisp off idle response and downlegs on the secondary's for overall air flow in my Quickfuel 770's. Tim I can see where that makes sense and even more so after reading the article.
[Re: DGS]
#2047359
04/05/16 08:23 PM
04/05/16 08:23 PM
Posts: 792 Earth
Rob C
Earth
I am running annualars on my primaries on the hemi for crisp off idle response and downlegs on the secondary's for overall air flow in my Quickfuel 770's. Tim I wanted to do the same but was told that I will get problems with fuel distribution between the different cylinders (fuel droplet size is different). I wouldn't believe that. Reason being is the need and how the engine reacts to the fuel at different engine speeds and loads. A fine mist for low speed and cruise conditions and bigger droplets of fuel for high load/speed (AKA - W.O.T.) Since driving on the primary side is probably better with the angular booster and the WOT works best with bigger droplets, the combo of boosters are a good theory to try out. Jetting is key to everything.
[Re: Rob C]
#2047373
04/05/16 08:48 PM
04/05/16 08:48 PM
Thumperdart
State of confusion
EVERYTHING being correct is the key............jetting is a good part of the fuel available and emulsion, angle channel size, booster type and outlet size, bleed size etc. all contribute to a "Clean n Mean" working carb............
[Re: Mark Whitener]
#2047932
04/06/16 01:44 PM
04/06/16 01:44 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Everything I build gets an annular booster as long as the carb size isn't restrictive. With annular boosters it allows you to use a larger carb and still get as good or better atomization, better distribution of fuel. That means power. And with some modified booster inserts airflow loss can be kept to a minimum. Mark would you explain modified booster inserts please? Thanks, Don
