70 gtx rallye dash problem #2036001
03/21/16 09:11 PM
03/21/16 09:11 PM
cmansell Offline OP
cmansell  Offline OP
I have temp and oil pressure gauges started pegging all the way over when key is on, thought I had a bad limiter until I found that when I turn the park lights on those gauges return to off position. This started after the airgrabber switch was taken out for repair. Anyone heard of this problem where light switch kills the gauges? I tried grounding the cluster with a jumper but no difference. Thanks
Re: 70 gtx rallye dash problem [Re: cmansell] #2036034
03/21/16 09:58 PM
03/21/16 09:58 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
bad ground to cluster ck the screw that hold it to the dash
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: 70 gtx rallye dash problem [Re: cmansell] #2036066
03/21/16 10:38 PM
03/21/16 10:38 PM
Andrewh Online content
Andrewh  Online Content
you may have 2 different problems.
pegging gauges are probably still the limiter.
killing them could also be a bad ground when you turn on the parking lights because they have no path to complete the circuit.
to peg the gauges, you must have more than 5 volts going to it.
I would pull out the limiter and bench test it before you burn out the gauges.
Re: 70 gtx rallye dash problem [Re: cmansell] #2036073
03/21/16 10:49 PM
03/21/16 10:49 PM
cmansell Offline OP
cmansell  Offline OP
I would have already changed the limiter, but it seems to be in the worst place to get it out without pulling the cluster. I can touch it but no room to pull it out. Console pistol grips are the worst for under dash work.
Re: 70 gtx rallye dash problem [Re: cmansell] #2036242
03/22/16 03:21 AM
03/22/16 03:21 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Try this...
Pull the radio panel with its 4 screws and rear bracket mount, disconnect antenna and wire lead. Now U can easily reach in to swap out the voltage limiter..
I would also suggest U install the new solid-state limiter
Just my $0.02... wink
Re: 70 gtx rallye dash problem [Re: cmansell] #2036243
03/22/16 03:21 AM
03/22/16 03:21 AM
midwest - USA
69/70 Plymies Offline
midwest - USA
Take the console out. I've spent the last 2 months working under the dash of my '70 Sport Satellite 4 speed/console car and it's real easy to pull the console. And if need be, pull a bucket seat out, too. Another easy job. I agree about bench testing the voltage limiter. Be sure to clean the dash ground located behind the passenger side kick panel.
Re: 70 gtx rallye dash problem [Re: cmansell] #2036696
03/22/16 07:44 PM
03/22/16 07:44 PM
cmansell Offline OP
cmansell  Offline OP
Pulled the radio out and looked at the rear of the cluster with a mirror, found a white wire dangling right above the lines to the airgrabber switch. Plugged it back up and everything came back. Unreal that a wire off would cause this problem!
