Re: Does anyone make a timing chain that isn't garbage? [Re: MadMopars] #2035943
03/21/16 08:01 PM
03/21/16 08:01 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
progear. Bought mine at hughes.
Re: Does anyone make a timing chain that isn't garbage? [Re: MadMopars] #2035945
03/21/16 08:04 PM
03/21/16 08:04 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Not sure if any of the latest comments were directed at me, but I worked in a motorcycle dealership for years, as well as racing motocross for many years and riding in the dirt for fun. I have a very good understanding of how chain & sprocket sets wear, whether they're connecting a crankshaft to a camshaft, or an output shaft to drive wheel.
Re: Does anyone make a timing chain that isn't garbage? [Re: MadMopars] #2035948
03/21/16 08:08 PM
03/21/16 08:08 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Comp Cams billet 9 way adjustable timing set, still nice and tight.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Does anyone make a timing chain that isn't garbage? [Re: slammedR/T] #2035953
03/21/16 08:17 PM
03/21/16 08:17 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
If you buy Rollmaster, buy the premium set with the Iwis chain. The cheaper versions don't have the same chain. This only happened with Rollmaster was sold to JP Products
Alan Jones
Re: Does anyone make a timing chain that isn't garbage? [Re: BradH] #2035970
03/21/16 08:35 PM
03/21/16 08:35 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Unless there is something deleted, the only person I saw say something about a chain stretching was the OP. It was just being pointed out that chains don't actually stretch. So where there is slack, the problem is the pins or the gears, not the chain itself
Re: Does anyone make a timing chain that isn't garbage? [Re: Monte_Smith] #2036055
03/21/16 10:17 PM
03/21/16 10:17 PM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
where can I buy a Rollmaster set at?
Re: Does anyone make a timing chain that isn't garbage? [Re: MadMopars] #2036080
03/21/16 11:01 PM
03/21/16 11:01 PM
slammedR/T Offline
slammedR/T  Offline
I had a JP performance chain way long time ago, it lasted 3000 miles before I went into the engine for something, the chain had a lot of slack in it. Hope they are better now....
racemagnum
Re: Does anyone make a timing chain that isn't garbage? [Re: madscientist] #2036089
03/21/16 11:12 PM
03/21/16 11:12 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Originally Posted By madscientist
Milodon gear drive and be done with it. Your valve timing will be the same a decade from now.
And before we get any further down the road, I would love to see any VERIFIED testing where gear drives cause harmonics. I have never seen it. The only testing I could find on the web was done by a nascar team and they tested a belt drive against a chain and a 4 gear drive. The 4 gear drive may be worse than a chain.
iagree x2
Re: Does anyone make a timing chain that isn't garbage? [Re: roadhazard] #2036139
03/22/16 12:12 AM
03/22/16 12:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been using the KB gear drives for years
now.. I have them on 2 other engines.. I wish
I had another to put on my 416 but I put a chain
on it
wave
Re: Does anyone make a timing chain that isn't garbage? [Re: MR_P_BODY] #2036146
03/22/16 12:21 AM
03/22/16 12:21 AM
Boise
Moparteacher Offline
Boise
Don't forget to soak the chain in oil prior to install. I work the chain in a bath of oil and then give it at least an hour prior to install.
BTW, all chains (pins) stretch in the first few thousand miles, and then the rate of stretch should slow. That's why another member suggested to re-degree and run it.
Re: Does anyone make a timing chain that isn't garbage? [Re: Moparteacher] #2036185
03/22/16 01:23 AM
03/22/16 01:23 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Going one step further, at Pettis we used to boil the chains in synthetic oil for quite a while w/great results.......
Re: Does anyone make a timing chain that isn't garbage? [Re: Moparteacher] #2036234
03/22/16 03:05 AM
03/22/16 03:05 AM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
It looks like I can buy a Cloyes replacement chain for $15. I'm tempted to grab one to see if the majority of the wear is in the chain or the sprockets. Even if it does arrive in time before Drag Weekend I'm not sure I would run it. There's a small part of me that thinks if I run the used chain it'll maintain cam timing better than if I installed the new chain.
Regardless, the next timing set I buy will be a Roll Master or Pro Gear with Iwis chain. Sadly, I am guessing it'll be sooner than later.
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Does anyone make a timing chain that isn't garbage? [Re: MadMopars] #2036266
03/22/16 06:54 AM
03/22/16 06:54 AM
Australia
Mcode69 Offline
Mcode69  Offline
Australia
I've got to say, I've got a 'Cloyes' set and it's been in the engine for 10 years or so, probably hasn't done a heap of miles, just a cruiser with an occasional trip to the track. Last time it was apart it was dead tight, that was some time ago but I rocked the engine back and forth with a breaker bar days ago and could not feel any slop. One thing though, when it went together I manufactured a nice oiling tab to drip oil into the centre of the bottom sprocket, maybe it likes it?
Re: Does anyone make a timing chain that isn't garbage? [Re: Mcode69] #2036550
03/22/16 04:21 PM
03/22/16 04:21 PM
Timing chain wear and stretch is determined by several things like quality, presoaking as well as the use including valve spring pressure and maximum RPM ran on each run cycle work shruggy I've used Cloyes mostly and the better True Roller seemed to last quite a while in my bracket motors shifting at 7000 RPM with flat tappet cams and valve spring pressures under 350 Lbs. My old Duster motor with a solid roller cam and 680 lbs spring pressures had the best Cloyes unit offered at that time, billet gears and so on and it failed , broke, after 2000 to 4000 street miles and hundreds of runs shifting it at or above 7000 RPM in each gear shruggy that chain never showed any stretching at all when I had the motor apart twice confused
Re: Does anyone make a timing chain that isn't garbage? [Re: MadMopars] #2036677
03/22/16 07:17 PM
03/22/16 07:17 PM
crabman173
crabman173
Stutter boxes kill chains
I always soak chains overnight then drip dry so they are not such a mess
hard to find a quality set these days
I like Progear
Re: Does anyone make a timing chain that isn't garbage? [Re: MadMopars] #2036748
03/22/16 09:16 PM
03/22/16 09:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my last rollmaster went about 5 easy seasons and looked good when i took it out because of a rebuild. Hung it on the wall and 6mths later when i needed it all the links were stiffened up and tight. Replaced it with a pro gear which is now in the race section for sale if any sb guys need a good chain(engine came apart on dyno). I will be getting another pro gear chain for the big block build.
Re: Does anyone make a timing chain that isn't garbage? [Re: MadMopars] #2036860
03/22/16 11:40 PM
03/22/16 11:40 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Had a Rollmaster last 19 years before I sold the engine. I bought it in 1994.
Mopar to the bone!!!
Re: Does anyone make a timing chain that isn't garbage? [Re: 72Swinger] #2038079
03/24/16 09:58 PM
03/24/16 09:58 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I just got a Comp Cams billet 9-way adjustable, It has a Rolon chain frown
The only Carbs I care about are under the hood!
Re: Does anyone make a timing chain that isn't garbage? [Re: ] #2038155
03/24/16 11:45 PM
03/24/16 11:45 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
I like Progear
iagree Inspect, clean, then soak in oil. I like to goop'em up w/assembly lube too and have had good luck w/Cloyes.
Yeah, it's got a smallblock.
Re: Does anyone make a timing chain that isn't garbage? [Re: MadMopars] #2040979
03/29/16 04:26 AM
03/29/16 04:26 AM
Tucson AZ,
Tucson AZ,
Just a quick update...
I installed the new replacement chain from Cloyes tonite. For less than 20 bucks I figured why not. The new chain when installed has substantially less slack in it than the previous chain. At the 8* mark the cam is now coming in at 102* installed centerline. At the 6* mark it's back to the 105* installed centerline I had acheived previously with the 8* mark and sloppy chain. Against what should be my better judgement, I left it at the 105* installed centerline with the new chain.
Long story short, the chain has less slop. It's almost as good as a new timing set but I still didn't have luck getting to the 104* I was looking for. I'm now a couple hours older and maybe a little wiser.
For what it's worth, I soaked the new chain in oil for about 30 minutes. Tomorrow I'll hit it with some assembly lube for good measure. I'll let you guys know how it worked out at the next tear down. Thanks again for the input! up
