Re: Does anyone make a timing chain that isn't garbage?
[Re: MadMopars]
#2035945
03/21/16 08:04 PM
03/21/16 08:04 PM
BradH
Not sure if any of the latest comments were directed at me, but I worked in a motorcycle dealership for years, as well as racing motocross for many years and riding in the dirt for fun. I have a very good understanding of how chain & sprocket sets wear, whether they're connecting a crankshaft to a camshaft, or an output shaft to drive wheel.
[Re: MadMopars]
#2035948
03/21/16 08:08 PM
03/21/16 08:08 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Comp Cams billet 9 way adjustable timing set, still nice and tight.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#2035953
03/21/16 08:17 PM
03/21/16 08:17 PM
Posts: 6,145 Melbourne , Australia
LA360
If you buy Rollmaster, buy the premium set with the Iwis chain. The cheaper versions don't have the same chain. This only happened with Rollmaster was sold to JP Products
Alan Jones
[Re: BradH]
#2035970
03/21/16 08:35 PM
03/21/16 08:35 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Not sure if any of the latest comments were directed at me, but I worked in a motorcycle dealership for years, as well as racing motocross for many years and riding in the dirt for fun. I have a very good understanding of how chain & sprocket sets wear, whether they're connecting a crankshaft to a camshaft, or an output shaft to drive wheel. Unless there is something deleted, the only person I saw say something about a chain stretching was the OP. It was just being pointed out that chains don't actually stretch. So where there is slack, the problem is the pins or the gears, not the chain itself
[Re: MadMopars]
#2036080
03/21/16 11:01 PM
03/21/16 11:01 PM
slammedR/T
I had a JP performance chain way long time ago, it lasted 3000 miles before I went into the engine for something, the chain had a lot of slack in it. Hope they are better now....
[Re: roadhazard]
#2036139
03/22/16 12:12 AM
03/22/16 12:12 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I've been using the KB gear drives for years now.. I have them on 2 other engines.. I wish I had another to put on my 416 but I put a chain on it
[Re: Moparteacher]
#2036185
03/22/16 01:23 AM
03/22/16 01:23 AM
Thumperdart
State of confusion
Don't forget to soak the chain in oil prior to install. I work the chain in a bath of oil and then give it at least an hour prior to install.
BTW, all chains (pins) stretch in the first few thousand miles, and then the rate of stretch should slow. That's why another member suggested to re-degree and run it. Going one step further, at Pettis we used to boil the chains in synthetic oil for quite a while w/great results.......
[Re: Mcode69]
#2036550
03/22/16 04:21 PM
03/22/16 04:21 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
Timing chain wear and stretch is determined by several things like quality, presoaking as well as the use including valve spring pressure and maximum RPM ran on each run cycle I've used Cloyes mostly and the better True Roller seemed to last quite a while in my bracket motors shifting at 7000 RPM with flat tappet cams and valve spring pressures under 350 Lbs. My old Duster motor with a solid roller cam and 680 lbs spring pressures had the best Cloyes unit offered at that time, billet gears and so on and it failed , broke, after 2000 to 4000 street miles and hundreds of runs shifting it at or above 7000 RPM in each gear that chain never showed any stretching at all when I had the motor apart twice
[Re: MadMopars]
#2036677
03/22/16 07:17 PM
03/22/16 07:17 PM
crabman173
crabman173
Stutter boxes kill chains I always soak chains overnight then drip dry so they are not such a mess hard to find a quality set these days I like Progear
[Re: MadMopars]
#2036860
03/22/16 11:40 PM
03/22/16 11:40 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Had a Rollmaster last 19 years before I sold the engine. I bought it in 1994.
Mopar to the bone!!!
[Re: ]
#2038155
03/24/16 11:45 PM
03/24/16 11:45 PM
Posts: 1,532 off the grid
340B5
off the grid
Stutter boxes kill chains I always soak chains overnight then drip dry so they are not such a mess hard to find a quality set these days I like Progear Inspect, clean, then soak in oil. I like to goop'em up w/assembly lube too and have had good luck w/Cloyes.
Yeah, it's got a smallblock.
[Re: MadMopars]
#2040979
03/29/16 04:26 AM
03/29/16 04:26 AM
Posts: 1,292 Tucson AZ,
MadMopars
Tucson AZ,
Just a quick update... I installed the new replacement chain from Cloyes tonite. For less than 20 bucks I figured why not. The new chain when installed has substantially less slack in it than the previous chain. At the 8* mark the cam is now coming in at 102* installed centerline. At the 6* mark it's back to the 105* installed centerline I had acheived previously with the 8* mark and sloppy chain. Against what should be my better judgement, I left it at the 105* installed centerline with the new chain. Long story short, the chain has less slop. It's almost as good as a new timing set but I still didn't have luck getting to the 104* I was looking for. I'm now a couple hours older and maybe a little wiser. For what it's worth, I soaked the new chain in oil for about 30 minutes. Tomorrow I'll hit it with some assembly lube for good measure. I'll let you guys know how it worked out at the next tear down. Thanks again for the input!
