Is my carb to small? #2033350
03/17/16 07:59 PM
03/17/16 07:59 PM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
I have a 750 holley dp with a holley hp main body. Im wondering if there is much to be gained switching to a larger carb. Like a 950 hp? My combo is a 470 ci comp solid cam lift intake.570 .573 lift exh. Durations at .050 is 251 int 258 exhaust. M1 intake 3800 stall converter, 4.10 rear gear in a 3800 pound car with me.
Re: Is my carb to small? [Re: Runner] #2033354
03/17/16 08:10 PM
03/17/16 08:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
DEFINITELY...............
Re: Is my carb to small? [Re: Runner] #2033356
03/17/16 08:16 PM
03/17/16 08:16 PM
UK
rb446 Offline
rb446  Offline
UK
x2
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Is my carb to small? [Re: Runner] #2033358
03/17/16 08:21 PM
03/17/16 08:21 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Needs a 850 cfm!
Have a great day
Iowan
"obsolete is neat"
Re: Is my carb to small? [Re: Runner] #2033371
03/17/16 08:42 PM
03/17/16 08:42 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Replaced my 750dp single plane intake on my 360 with a Ported 6 pack intake and the old mechanical direct connection 6 pack carbs that have a true 1,000 + CFM and it's faster so I would say YES.
Re: Is my carb to small? [Re: Runner] #2033397
03/17/16 09:38 PM
03/17/16 09:38 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
950. Maybe. 850. Absolutely.
[image][/image]
Re: Is my carb to small? [Re: ademon] #2033408
03/17/16 09:53 PM
03/17/16 09:53 PM
dogdays Offline
dogdays  Offline
I think it's a slam dunk. If you're buying a 950HP carb, make sure it's one of the newer ones that were actually 950 cfm, and not the earlier ones that the 950 was just a name.
R.
Re: Is my carb to small? [Re: Runner] #2033433
03/17/16 10:22 PM
03/17/16 10:22 PM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
what do you guys think im leaving on the table staying with the 750?
Re: Is my carb to small? [Re: Runner] #2033449
03/17/16 10:52 PM
03/17/16 10:52 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
ET and MPH....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Is my carb to small? [Re: D-50] #2033487
03/17/16 11:30 PM
03/17/16 11:30 PM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
i have not ran this combo yet, hope i picked some up over the old engine. my old motor was the same edelbrock heads, unported with a little smaller cam (comp xe282s). and 452 ci. it went 11.49@117 on the coast (woodburn oregon in july) with clocks i trust. the closest 1/4 mile is spokane washington and at that track its gone 11.75@115 after they put a new timing system in. with thier old timing system it went 11.35@119. our closest 1/8th mile track it went 7.34@93.9
Re: Is my carb to small? [Re: Runner] #2033497
03/17/16 11:41 PM
03/17/16 11:41 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Just put a new 4150 1000cfm Quick Fuel on a mild 446 with Indy heads, went 11.2 @ 123 first night out on street tyres.
You have already been convinced but yeah you need more !!!
1963 Plymouth Max Wedge
1971 Barracuda
Re: Is my carb to small? [Re: Runner] #2033500
03/17/16 11:45 PM
03/17/16 11:45 PM
I ain't a drag racer but the Q reminded me of a statement by my advanced tune up instructor way back who stated that if you have over 1" of vac at WOT then the carb is too small (too much restriction at the venturis)
Re: Is my carb to small? [Re: RapidRobert] #2033503
03/17/16 11:52 PM
03/17/16 11:52 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I have ALWAYS went faster going to a bigger carb Up to 1050 on a small block.
Re: Is my carb to small? [Re: Runner] #2033519
03/18/16 12:20 AM
03/18/16 12:20 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yeah, I'm sure there's room for improvement with a different carb. But you can't just go by the carb's advertised size; you need to take into account venturi size, throttle plate diameter and booster type.
A Holley Ultra 950 HP with a 1.60" venturi is going to run differently than a Quick Fuel Q-950 with a 1.45" venturi... and, NO, bigger isn't necessarily better when it comes down to what makes a particular combination go down the track faster.
Re: Is my carb to small? [Re: BradH] #2033531
03/18/16 12:32 AM
03/18/16 12:32 AM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
Brad, i got a quote from prosystems, he suggested a 950 with his blocks ect. i might go that way. he mentioned gains that seemed like alot to me. am i leaving 25-30 hp on the table with what i have? or am i leaving 5-10? i guess thats what im wondering.
Re: Is my carb to small? [Re: Runner] #2033536
03/18/16 12:38 AM
03/18/16 12:38 AM
AndyF Offline
AndyF  Offline
Put a vacuum gauge on it and see what it says at WOT. That is probably the best way to see if you need a larger carb.
No doubt that a larger carb will make more power at WOT on your engine but you might not like the larger carb on the street. All depends how you use the car. If it was my car I wouldn't spend the money for a new carb but if a good deal came along I might pick up another carb just for fun.
I had a like new 1000 HP Holley for sale on here for $400 not too long ago. That is the kind of deal that you might want to take advantage of.
Re: Is my carb to small? [Re: Runner] #2033554
03/18/16 01:11 AM
03/18/16 01:11 AM
BradH Offline
BradH  Offline
Is PJ saying his "950" is worth 25+ HP over your current carb? Seems like a he11uva lot... but I don't build & sell carbs for a living.
Re: Is my carb to small? [Re: Runner] #2033559
03/18/16 01:17 AM
03/18/16 01:17 AM
sgcuda Offline
sgcuda  Offline
If you are going to buy a carb, and then start changing it around, can I suggest you talk to ThumperDart first. He can modify an out of the box piece or build you a whole custom carb for your combo. He's a straight shooter and knows his stuff.
[image][/image]
Re: Is my carb to small? [Re: Runner] #2033588
03/18/16 02:57 AM
03/18/16 02:57 AM
Idaho
Runner Offline OP
Runner  Offline OP
Idaho
andy, i seen that deal but by the time i did it was gone frown.
Re: Is my carb to small? [Re: Runner] #2033597
03/18/16 04:17 AM
03/18/16 04:17 AM
Cab_Burge Online work
Cab_Burge  Online Work
That many inches and those heads your leaving a lot on the table twocents I have used a bunch of different size carbs. on motors like yours, both stock stroke an bigger stroke than yours, all of them like the bigger carbs.(850CFM+) at the track thumbs shruggy I do have several Holleys on the shelf collecting dust if you want to borrow a couple of different ones to try them, 850 Holley D.P. and Holley 1000 HP with annular boosters as well as several 1050 CFM Dominators devil whistling AKA, let me know if you want to try a couple of them thumbs When does Walla Walla season start?
