dana 60 clunking in reverse #2032033
03/16/16 12:16 AM
03/16/16 12:16 AM
wisconsin united states
K
keith airgrabber Offline OP
Right in the Nutz!!!
K
1972 dana 60 3:54 is making a clunking chatter noise in reverse. Drive shaft is fine. Could it be loose spider gears? Gonna take the cover off and see when I get a chance. Is there 4 spider gears and do two turn onl when turning the car? Not sure. I noticed my car sometimes is not a sure grip. Any input would be awesome.thanks
Re: dana 60 clunking in reverse [Re: keith airgrabber] #2032057
03/16/16 12:43 AM
03/16/16 12:43 AM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Mine needed a tube of anti-slip additive added and it went away. Modern lubes say they are formulated for sure grips, but they need the additional additive in my experience.
Re: dana 60 clunking in reverse [Re: keith airgrabber] #2032119
03/16/16 01:46 AM
03/16/16 01:46 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I agree. Sounds like you need to change the fluid and add a fresh bottle of Ford friction modifier.
Re: dana 60 clunking in reverse [Re: DoctorDiff] #2032129
03/16/16 02:02 AM
03/16/16 02:02 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Had the same problem with mine, added a bottle of GM friction Modifyer. Problem solved.
Abe Lincoln
Re: dana 60 clunking in reverse [Re: dart4forte] #2032219
03/16/16 09:54 AM
03/16/16 09:54 AM
K
K
I put 90 weight in it a few years back. So this could be the problem? What do I do ,drain it and put 80 weight in it and the friction limited slip modifier? Thanks, this could be a pretty easy fix.
Re: dana 60 clunking in reverse [Re: keith airgrabber] #2032292
03/16/16 12:02 PM
03/16/16 12:02 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I would try the friction modifier first.
Abe Lincoln
Re: dana 60 clunking in reverse [Re: keith airgrabber] #2032352
03/16/16 01:23 PM
03/16/16 01:23 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Have you removed the drums to make sure it's not the brake shoes grabbing the drums? The one wheel peel also could mean the clutches are worn especially if it's the later Trac-loc unit twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: dana 60 clunking in reverse [Re: fourgearsavoy] #2032368
03/16/16 01:49 PM
03/16/16 01:49 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I had the same issue, and it was a carrier bearing getting ready to explode, ask me how it worked for me... realmad
JB Rhinehart, Realist
A-Body's RULE!
Re: dana 60 clunking in reverse [Re: Rhinodart] #2032482
03/16/16 04:58 PM
03/16/16 04:58 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I would jack up the car, set the parking brake to lock the rear, unbolt the drive shaft and drain the rear of oil. When it finally has stopped draining, put a 1 & 5/16s socket on the pinion nut and using a breaker bar crank it back & forth while observing the movement of the carrier. You should be able to see movement in backlash, bearings, spiders, etc. And the condition of the gear oil would be a good test too. Shiny, glittering gear oil is not a good thing, DAMHIK.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
