Re: dana 60 clunking in reverse
[Re: DoctorDiff]
#2032129
03/16/16 02:02 AM
03/16/16 02:02 AM
Posts: 16,147 Mesa, Arizona
dart4forte
Mesa, Arizona
Had the same problem with mine, added a bottle of GM friction Modifyer. Problem solved.
Abe Lincoln
[Re: keith airgrabber]
#2032292
03/16/16 12:02 PM
03/16/16 12:02 PM
dart4forte
Mesa, Arizona
I put 90 weight in it a few years back. So this could be the problem? What do I do ,drain it and put 80 weight in it and the friction limited slip modifier? Thanks, this could be a pretty easy fix. I would try the friction modifier first.
Abe Lincoln
[Re: Rhinodart]
#2032482
03/16/16 04:58 PM
03/16/16 04:58 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I would jack up the car, set the parking brake to lock the rear, unbolt the drive shaft and drain the rear of oil. When it finally has stopped draining, put a 1 & 5/16s socket on the pinion nut and using a breaker bar crank it back & forth while observing the movement of the carrier. You should be able to see movement in backlash, bearings, spiders, etc. And the condition of the gear oil would be a good test too. Shiny, glittering gear oil is not a good thing, DAMHIK.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
