hot or cold plugs #2031294
03/14/16 11:39 PM
03/14/16 11:39 PM
gulfport, ms, west mi
rowin4 Offline OP
rowin4  Offline OP
What are you guys using for spark plugs that have big blocks with Edelbrock RPM Performer heads?
Re: hot or cold plugs [Re: rowin4] #2031440
03/15/16 02:40 AM
03/15/16 02:40 AM
It depends on the mecahnical, not dynamic,compression ratio, shift RPM and fuel being used thumbs Whar are yours work
Re: hot or cold plugs [Re: rowin4] #2031485
03/15/16 08:36 AM
03/15/16 08:36 AM
crabman173
crabman173
NGK has the best tech line in the business--call them and they will put you dead on like a Nascar crew chief
Re: hot or cold plugs [Re: rowin4] #2031608
03/15/16 12:56 PM
03/15/16 12:56 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
3924's
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: hot or cold plugs [Re: rowin4] #2031640
03/15/16 01:56 PM
03/15/16 01:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m at 12.1.1 comp. and run a 7 or 8 NGK`s depending on my tune. The 7 can speckle a bit if the engine temps up there and the tune isn`t.............. biggrin
Re: hot or cold plugs [Re: rowin4] #2031648
03/15/16 02:07 PM
03/15/16 02:07 PM
rowin4 Offline OP
rowin4  Offline OP
It's a 505 pump gas engine with Edelbrock RPM heads. The reason I asked is I have been running Autolite AR3924's , a friend of mine runs Autolite AR3933's. I don't recall why I have been running these plugs or if I should be running something different. SO?
Re: hot or cold plugs [Re: rowin4] #2031649
03/15/16 02:09 PM
03/15/16 02:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I only run NGK`s so not sure on those..............
Re: hot or cold plugs [Re: rowin4] #2031655
03/15/16 02:22 PM
03/15/16 02:22 PM
The 3933 are non resitor and I think a retracted gap. The 3924 are a resitor with a extended gap, the 3933 is one step colder than 3924. IHTH
Re: hot or cold plugs [Re: rowin4] #2031772
03/15/16 05:09 PM
03/15/16 05:09 PM
rowin4 Offline OP
rowin4  Offline OP
OK, so should I run a resistor or non resistor plug with MSD ignition?
Re: hot or cold plugs [Re: rowin4] #2031808
03/15/16 06:15 PM
03/15/16 06:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
try the 3924 resister plugs first. if they're too warm step down to a 3923. msd's have to have resistance in the system; whether it's the wires, ballast or plugs, or combination. an ap3924 has 5000 ohns, regular 3924 7000 ohms; tested some rc12y's at 70,000 ohms! most resistor plugs will be 5000 or more ohms. of course non-resistor should be zero. if you're by-passing the ballast then more resistance will need to be in the plugs and wires.
Re: hot or cold plugs [Re: lewtot184] #2031836
03/15/16 07:26 PM
03/15/16 07:26 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
NGK recommends the following plugs for Edelbrock heads.
R5672A-7 is a non resistor race plug. -7 is the hottest plug they offer. -11 is the coldest one. This is a projected tip spark plug. Use R5671 for domed pistons.
BCPR6ES is a resistor type street plug.(Stock #6779) This is what I currently use on my 383 Road Runner with MSD ignition. These are available in heat ranges 4 thru 9
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: hot or cold plugs [Re: rowin4] #2031839
03/15/16 07:39 PM
03/15/16 07:39 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
According to MSD website either will work just fine but you should use resistor type plugs for less radio interference if that is a concern.
Re: hot or cold plugs [Re: rowin4] #2031851
03/15/16 08:00 PM
03/15/16 08:00 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
msd's have to have some resistance in the system, race/street or whatever.
Re: hot or cold plugs [Re: lewtot184] #2031859
03/15/16 08:12 PM
03/15/16 08:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm using the 3924 in my 416 injected engine
wave
Re: hot or cold plugs [Re: MR_P_BODY] #2031877
03/15/16 09:00 PM
03/15/16 09:00 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
wave
I have been running a AR3933 plug and was thinking about running one a step hotter. Which one would that be a AR3932 or AR3934.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: hot or cold plugs [Re: D-50] #2031943
03/15/16 10:33 PM
03/15/16 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The 3924 is what I was told
wave
Re: hot or cold plugs [Re: rowin4] #2032106
03/16/16 01:38 AM
03/16/16 01:38 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I ran ar3934 in my 493 for years. Probably the same plugs as I dont change them. I tried ngk and champions at DW12 and went back to the ar3934 very quickly
Re: hot or cold plugs [Re: D-50] #2032120
03/16/16 01:47 AM
03/16/16 01:47 AM
wave
On Autolite plugs the smaller the number the colder the plug, 3934 are the next hotter from the 3933 thumbs
Re: hot or cold plugs [Re: rowin4] #2032224
03/16/16 10:03 AM
03/16/16 10:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Everything you want to know about Autolite plugs. BTW I run AR3911s in my small blocks.
http://www.autolite.com/technical-resources/tech-specs.aspx
Re: hot or cold plugs [Re: Ray440] #2032303
03/16/16 12:16 PM
03/16/16 12:16 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Do you have a link? Everything I see on their website says not to run a non-resistor plug, resistor plugs only with MSD.
