hot or cold plugs
#2031294
03/14/16 11:39 PM
03/14/16 11:39 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
What are you guys using for spark plugs that have big blocks with Edelbrock RPM Performer heads?
Re: hot or cold plugs
[Re: rowin4]
#2031485
03/15/16 08:36 AM
03/15/16 08:36 AM
crabman173
crabman173
NGK has the best tech line in the business--call them and they will put you dead on like a Nascar crew chief
[Re: rowin4]
#2031640
03/15/16 01:56 PM
03/15/16 01:56 PM
Thumperdart
State of confusion
I`m at 12.1.1 comp. and run a 7 or 8 NGK`s depending on my tune. The 7 can speckle a bit if the engine temps up there and the tune isn`t..............
[Re: rowin4]
#2031648
03/15/16 02:07 PM
03/15/16 02:07 PM
rowin4
It's a 505 pump gas engine with Edelbrock RPM heads. The reason I asked is I have been running Autolite AR3924's , a friend of mine runs Autolite AR3933's. I don't recall why I have been running these plugs or if I should be running something different. SO?
[Re: rowin4]
#2031649
03/15/16 02:09 PM
03/15/16 02:09 PM
Thumperdart
State of confusion
I only run NGK`s so not sure on those..............
[Re: rowin4]
#2031655
03/15/16 02:22 PM
03/15/16 02:22 PM
Posts: 43,241 Bend,OR USA
Cab_Burge
The 3933 are non resitor and I think a retracted gap. The 3924 are a resitor with a extended gap, the 3933 is one step colder than 3924. IHTH
[Re: rowin4]
#2031772
03/15/16 05:09 PM
03/15/16 05:09 PM
rowin4
OK, so should I run a resistor or non resistor plug with MSD ignition?
[Re: rowin4]
#2031808
03/15/16 06:15 PM
03/15/16 06:15 PM
Posts: 3,916 usa
lewtot184
usa
try the 3924 resister plugs first. if they're too warm step down to a 3923. msd's have to have resistance in the system; whether it's the wires, ballast or plugs, or combination. an ap3924 has 5000 ohns, regular 3924 7000 ohms; tested some rc12y's at 70,000 ohms! most resistor plugs will be 5000 or more ohms. of course non-resistor should be zero. if you're by-passing the ballast then more resistance will need to be in the plugs and wires.
[Re: lewtot184]
#2031836
03/15/16 07:26 PM
03/15/16 07:26 PM
Posts: 1,770 Wethersfield,CT
Ray440
Wethersfield,CT
NGK recommends the following plugs for Edelbrock heads. R5672A-7 is a non resistor race plug. -7 is the hottest plug they offer. -11 is the coldest one. This is a projected tip spark plug. Use R5671 for domed pistons. BCPR6ES is a resistor type street plug.(Stock #6779) This is what I currently use on my 383 Road Runner with MSD ignition. These are available in heat ranges 4 thru 9
1969 Plymouth Road Runner 440 auto 2017 Ram 1500 Quad Cab 5.7 Hemi
[Re: rowin4]
#2031839
03/15/16 07:39 PM
03/15/16 07:39 PM
Ray440
Wethersfield,CT
OK, so should I run a resistor or non resistor plug with MSD ignition? According to MSD website either will work just fine but you should use resistor type plugs for less radio interference if that is a concern.
[Re: MR_P_BODY]
#2031877
03/15/16 09:00 PM
03/15/16 09:00 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I'm using the 3924 in my 416 injected engine I have been running a AR3933 plug and was thinking about running one a step hotter. Which one would that be a AR3932 or AR3934.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: rowin4]
#2032106
03/16/16 01:38 AM
03/16/16 01:38 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I ran ar3934 in my 493 for years. Probably the same plugs as I dont change them. I tried ngk and champions at DW12 and went back to the ar3934 very quickly
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: D-50]
#2032120
03/16/16 01:47 AM
03/16/16 01:47 AM
Cab_Burge
I'm using the 3924 in my 416 injected engine I have been running a AR3933 plug and was thinking about running one a step hotter. Which one would that be a AR3932 or AR3934. On Autolite plugs the smaller the number the colder the plug, 3934 are the next hotter from the 3933
[Re: Ray440]
#2032303
03/16/16 12:16 PM
03/16/16 12:16 PM
Posts: 5,164 CT
GTX MATT
CT
OK, so should I run a resistor or non resistor plug with MSD ignition? According to MSD website either will work just fine but you should use resistor type plugs for less radio interference if that is a concern. Do you have a link? Everything I see on their website says not to run a non-resistor plug, resistor plugs only with MSD.
