Re: Steering Column Bushing - Mid '70's
[Re: 70Duster440]
#2025736
03/06/16 02:38 PM
03/06/16 02:38 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
the newer trucks (80s) have a bearing there to support the shaft. It needs to be supported.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: 70Duster440]
#2027690
03/09/16 02:45 AM
03/09/16 02:45 AM
Posts: 1,069 Washington State
70Duster440
Washington State
Well, we broke the column down and painted the pieces last weekend and then decided to take another look at some kind of bearing support. So, I picked up a flanged bearing with a 2" OD and .75" ID, some nuts, and set screws. Had already cut off the end of the column tube before painting. Ground some flats in the outer race for the set screws to contact. Seems the column and shaft will have to be much more accurately aligned with the steering box. We'll see how it works.
[Re: stumpy]
#2027694
03/09/16 02:56 AM
03/09/16 02:56 AM
70Duster440
Washington State
Are you going to install the steering gear box reinforcement bracket on the truck also? Was offered a used one but the seller didn't follow through.
