Coolant leak from timing chain cover? *DELETED* #203073
01/24/09 03:41 PM
01/24/09 03:41 PM
central PA
mopartial Offline OP
central PA
Post deleted by mopartial
If it aint broke, dont break it.
Re: Coolant leak from timing chain cover? [Re: mopartial] #203074
01/24/09 03:44 PM
01/24/09 03:44 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Most likely the timing cover gasket is leaking or it could be corrosion of the cover itself. Check bypass hose too. Also check your oil for signs of coolant too. Mike
Re: Coolant leak from timing chain cover? [Re: mopartial] #203075
01/24/09 03:45 PM
01/24/09 03:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
why would you think it's dry , the cover is part of the cooling system , the water pump bolts directly to it and has a cavity and passages filled with coolant .
But first check for a leaking hose above that point ?
Re: Coolant leak from timing chain cover? [Re: JohnRR] #203076
01/24/09 03:52 PM
01/24/09 03:52 PM
central PA
central PA
I wish it was a hose, but I can see a geyser of coolant coming out btn cover and front of block.
I was thinking timing chain is bathed in oil, not coolant, so was surprised to see coolant there. Never said I was smart...
Thanks for replies. My mechanic gets this one...
Re: Coolant leak from timing chain cover? [Re: mopartial] #203077
01/24/09 04:17 PM
01/24/09 04:17 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
why deleted?
Re: Coolant leak from timing chain cover? [Re: 05dakota] #203078
01/24/09 04:27 PM
01/24/09 04:27 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
He evidently didn't like the answers he got.
Re: Coolant leak from timing chain cover? [Re: MoparforLife] #203079
01/24/09 04:39 PM
01/24/09 04:39 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Maybe johnrrs answer? I don`t know. I did n`t say anything to offend anyone.
