Converter question #2029395
03/11/16 08:28 PM
03/11/16 08:28 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
Will the ring gear be smaller on a 904 compared to a 727?
Re: Converter question [Re: sixpackgut] #2029459
03/11/16 10:43 PM
03/11/16 10:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
904 converter has 122 teeth on the ring gear, 727 has 130.
Re: Converter question [Re: sixpackgut] #2029537
03/12/16 12:34 AM
03/12/16 12:34 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Whatcha up to Ray........... work
Re: Converter question [Re: sixpackgut] #2029614
03/12/16 02:22 AM
03/12/16 02:22 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Loosing weight going to 904 trans
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Converter question [Re: 1967dartgt] #2029641
03/12/16 03:18 AM
03/12/16 03:18 AM
Charleston
Charleston
Im going to cut 8 teeth out of a ring gear and weigh it
Re: Converter question [Re: sixpackgut] #2029708
03/12/16 11:58 AM
03/12/16 11:58 AM
NC USA
U
ultimatelenny Offline
U
NC USA
The bellhousing and starter location is smaller on the 904 to accommodate the 904-122 ring gear
Lenny Croteau www.ultimateconverter.com Phone 704-892-6837 Fax 704-892-6880
Re: Converter question [Re: ultimatelenny] #2029781
03/12/16 02:21 PM
03/12/16 02:21 PM
Charleston
Charleston
Its weird because i had to grind the side of my block to fit the starter with the 727. So as soon as i saw the smaller ring gear i got worried but the starter fits
Re: Converter question [Re: sixpackgut] #2029795
03/12/16 02:54 PM
03/12/16 02:54 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I run a 904, and had to grind my Magnum block for the starter to fit, But fit ok on my R block with out grinding.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Converter question [Re: sixpackgut] #2029884
03/12/16 07:21 PM
03/12/16 07:21 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I know everyone will find this surprising, but I run a R-3 block with a 904 and I had to grind the block a little to get the starter to bolt up flush to the transmission.
So like everything else, your mileage may vary!
Bill
