Re: Ritter Cast Iron SBM Block
[Re: Wailin D]
#2028815
03/10/16 09:58 PM
03/10/16 09:58 PM
Triple Threat
Renton Washington
The sad part is if he fixed the problems they have that the blocks would sell. The market for R3's is limited, and getting smaller each day.
Until they're proven by him or others, the buyers are going to be few and far between.
[Re: Wailin D]
#2029006
03/11/16 03:59 AM
03/11/16 03:59 AM
Posts: 6,142 Melbourne , Australia
LA360
An engine shop in Australia was appointed as a sole distributor late last year via a Facebook post. The issues were brought up in the comments, to which the vendor was advised by Kent they were all resolved. Didn't really carry any weight with me as the picture of the block they were using had an obvious machining flaw. The castings appear to be good, the machining is done by the cheapest people Kent could find, hence all the problems. It's a downright shame
Alan Jones
[Re: Wailin D]
#2029104
03/11/16 11:47 AM
03/11/16 11:47 AM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
Sorry gentlemen, I can't address your questions. My post was simply to share my conversation and provide contact information. We did not talk about the aluminum block in detail. I wasn't aware of the issues with the cast iron block, just that there was a need for one. ...and that's why it's nice to talk about. There have been people that spent thousands just to end up scrapping their projects. The ONLY iron Ritter block that I've EVER heard that is running (and running damn hard I might add) is our own member Whitedart..... but as he's noted here, it wasn't easy, and it wasn't cheap. Fought a lot of one off issues. Worked around things that were just plain wrong. Like I said before.... the best thing that could happen would be for Kent to get a block to a builder, and have them do a detailed build that would prove that this block is in a usable state. If that happened I believe he would start to move some blocks.
[Re: J_BODY]
#2029111
03/11/16 12:00 PM
03/11/16 12:00 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
That request has been asked and ignored many times.We would love to do a detailed build and follow it's performance in one of our cars at the track.We promise to be "fair and balanced" and we appreciate Kent's effort to make casting available and would like to see his effort succeed.
[Re: justinp61]
#2029231
03/11/16 03:31 PM
03/11/16 03:31 PM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
IMO if he keeps messing around and the aftermarket ever blows open for Genlll stuff he's sunk.
Just a side note but he is in the G3 market, he happens to be the guy doing the big drag pak looking intakes that Muscle Motors and Hughes sells.
[Re: sst404b]
#2029254
03/11/16 03:55 PM
03/11/16 03:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The blocks were right around $3000 each not much more than the R3 stuff and btw we had to work on the last R3 that we did to get it right
Ray Buckner Ok... I was running a R3 and yes it took the normal stuff to get it to the assembly point but it was just normal stuff.. line hone, bore and hone the cam tunnel, bores and decking... I cant remember if I did the lifter bushings or not (I think I did).. mine was a dry sump block so I went with the 4 stage pump
[Re: SpareParts]
#2029272
03/11/16 04:24 PM
03/11/16 04:24 PM
Triple Threat
Renton Washington
Just a side note but he is in the G3 market, he happens to be the guy doing the big drag pak looking intakes that Muscle Motors and Hughes sells. This is true, also true that one of the bolt holes on mine to mount the carburetor was threaded at a fairly severe angle. No way you could put a carb on it as came. Minor issue in the grand scheme, but makes you think twice about buying a whole block from the same source.
