Re: Ritter Cast Iron SBM Block [Re: MR_P_BODY] #2029316
03/11/16 05:59 PM
03/11/16 05:59 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I believe the aluminum blocks are 4 grand. There is a member on here that has the aluminum block. I talked to him personally about the issues I had with a iron block & the only problem he had with it was the oil drain back which he corrected himself. Everything else was good. Maybe the aluminum block maybe the way to go.
Re: Ritter Cast Iron SBM Block [Re: rickraw] #2029317
03/11/16 06:05 PM
03/11/16 06:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks for the info... yeah maybe the alum up it
would help to dump so weight in the front anyways..
are his alum blocks 48* or 59* or either
wave
Re: Ritter Cast Iron SBM Block [Re: MR_P_BODY] #2029325
03/11/16 06:26 PM
03/11/16 06:26 PM
Kansas, Topeka
69 lawndart Offline
69 lawndart  Offline
Kansas, Topeka
You can get the Aluminum block in 48 or 59 deg.
Re: Ritter Cast Iron SBM Block [Re: 69 lawndart] #2029331
03/11/16 06:30 PM
03/11/16 06:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Any issues with the alum 59* block.. thanks
wave
Re: Ritter Cast Iron SBM Block [Re: Wailin D] #2029345
03/11/16 06:55 PM
03/11/16 06:55 PM
Kansas, Topeka
69 lawndart Offline
69 lawndart  Offline
Kansas, Topeka
I have no idea about the 59 mine is a 48.
Re: Ritter Cast Iron SBM Block [Re: 69 lawndart] #2029350
03/11/16 07:10 PM
03/11/16 07:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thanks... I seen your update.. when do you figure
for the dyno
wave
Re: Ritter Cast Iron SBM Block [Re: Wailin D] #2029376
03/11/16 08:03 PM
03/11/16 08:03 PM
Can , Nova Scotia , Cape Breto...
caper Offline
caper  Offline
If you are looking for a Ritter block, there is one at FHO, a friend of mine owned it, he died about 2 years ago and I think it is for sale. Give them a call and ask about Blair's block. Or send me Pm and I will try to find out more info for ya.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
Re: Ritter Cast Iron SBM Block [Re: caper] #2029377
03/11/16 08:05 PM
03/11/16 08:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you know if its a 48* or 59* block.. thanks
EDIT
Is it alum
wave
Re: Ritter Cast Iron SBM Block [Re: Wailin D] #2029429
03/11/16 09:37 PM
03/11/16 09:37 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
So what are these machining problems, exactly? That covers a lot of ground. S/F....Ken M
Re: Ritter Cast Iron SBM Block [Re: EchoSixMike] #2029454
03/11/16 10:39 PM
03/11/16 10:39 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Do u really want to know
Re: Ritter Cast Iron SBM Block [Re: Wailin D] #2029547
03/12/16 12:42 AM
03/12/16 12:42 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Why would I ask and not want to know? I work in a machine shop. "There's problems" doesn't mean anything without details. S/F....Ken M
Re: Ritter Cast Iron SBM Block [Re: Wailin D] #2029702
03/12/16 11:37 AM
03/12/16 11:37 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Good place to work if you're going to give it a swing Ken. I'd pm Whitedart and maybe see if you can get his phone number.... might be a bit of a long conversation. If you search the site you can find some of his older posts that mention some of the issues he ran into. I also noted in an earlier post that qwkmopardan had said he had gotten a 59 degree Ritter/ebrock deal running. Might be worth asking him. As noted Rickraw had one and got his money back. I also know another gentleman in Michigan that dumped money into one and gave up. I was dangerously close to going the Ritter route in 12, but was "swayed" by a few to go R3 since I work at a dealer.
Re: Ritter Cast Iron SBM Block [Re: Wailin D] #2029741
03/12/16 01:14 PM
03/12/16 01:14 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
To be fair, I'm a big block guy, but a friend is doing a killer W8/R3 deal, so I'm curious, plus there's always customers coming in with broken $hit. S/F....Ken M
Re: Ritter Cast Iron SBM Block [Re: sst404b] #2030215
03/13/16 01:19 PM
03/13/16 01:19 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Originally Posted By sst404b
We have 2 of them going together at Allen Shermans shop in Texas 1 will be a 340 stocker
Ray Buckner
What did the 340 stocker bare block end up weighing?
Re: Ritter Cast Iron SBM Block [Re: LSP] #2030317
03/13/16 04:20 PM
03/13/16 04:20 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Can the Ali block use the P7 or even Better the P5 heads?
Matt
Re: Ritter Cast Iron SBM Block [Re: MattW] #2030456
03/13/16 07:51 PM
03/13/16 07:51 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The block for p7 heads has more/different spaced cam bearing bulkheads.
Re: Ritter Cast Iron SBM Block [Re: Wailin D] #2030542
03/13/16 10:00 PM
03/13/16 10:00 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I have a new aluminum tall deck with p7's going together now.The aluminum block so far seems like the way to go.It all pressure tested great and no major problems at all.I had a aluminum mopar block before this one and had to fix more problems on it.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Ritter Cast Iron SBM Block [Re: bdaz smblk] #2030822
03/14/16 11:39 AM
03/14/16 11:39 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
This is good to know, waiting to see this one make some steam.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
