Re: Ritter Cast Iron SBM Block
[Re: rickraw]
#2029317
03/11/16 06:05 PM
03/11/16 06:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I believe the aluminum blocks are 4 grand. There is a member on here that has the aluminum block. I talked to him personally about the issues I had with a iron block & the only problem he had with it was the oil drain back which he corrected himself. Everything else was good. Maybe the aluminum block maybe the way to go. Thanks for the info... yeah maybe the alum ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) it would help to dump so weight in the front anyways.. are his alum blocks 48* or 59* or either ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: 69 lawndart]
#2029350
03/11/16 07:10 PM
03/11/16 07:10 PM
MR_P_BODY
I have no idea about the 59 mine is a 48. thanks... I seen your update.. when do you figure for the dyno ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: Wailin D]
#2029376
03/11/16 08:03 PM
03/11/16 08:03 PM
Posts: 525 Can , Nova Scotia , Cape Breto...
caper
If you are looking for a Ritter block, there is one at FHO, a friend of mine owned it, he died about 2 years ago and I think it is for sale. Give them a call and ask about Blair's block. Or send me Pm and I will try to find out more info for ya.
New best 10.18 , 1.40 60 ft 496 Scott Brown built, street driven 3600 lbs,654 hp , 653 ft tq
[Re: caper]
#2029377
03/11/16 08:05 PM
03/11/16 08:05 PM
MR_P_BODY
If you are looking for a Ritter block, there is one at FHO, a friend of mine owned it, he died about 2 years ago and I think it is for sale. Give them a call and ask about Blair's block. Or send me Pm and I will try to find out more info for ya. Do you know if its a 48* or 59* block.. thanks EDIT Is it alum
[Re: sst404b]
#2030215
03/13/16 01:19 PM
03/13/16 01:19 PM
Posts: 1,314 Charlotte, NC
LSP
Charlotte, NC
We have 2 of them going together at Allen Shermans shop in Texas 1 will be a 340 stocker
Ray Buckner What did the 340 stocker bare block end up weighing?
[Re: MattW]
#2030456
03/13/16 07:51 PM
03/13/16 07:51 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The block for p7 heads has more/different spaced cam bearing bulkheads.
[Re: Wailin D]
#2030542
03/13/16 10:00 PM
03/13/16 10:00 PM
Posts: 437 south central pa
bdaz smblk
south central pa
I have a new aluminum tall deck with p7's going together now.The aluminum block so far seems like the way to go.It all pressure tested great and no major problems at all.I had a aluminum mopar block before this one and had to fix more problems on it.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: bdaz smblk]
#2030822
03/14/16 11:39 AM
03/14/16 11:39 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have a new aluminum tall deck with p7's going together now.The aluminum block so far seems like the way to go.It all pressure tested great and no major problems at all.I had a aluminum mopar block before this one and had to fix more problems on it. This is good to know, waiting to see this one make some steam.
Brett Miller W9 cnc'd heads STR Chassis fabraction
