C-body brake question #2028333
03/10/16 03:36 AM
03/10/16 03:36 AM
Fort Lee, VA
BattleCruiser71 Offline OP
Fort Lee, VA
Hey all, I'm considering a 70 Newport for a road trip and project, very original, 383-2bbl car, but the guy doesn't remember if it's power or manual brakes, drum or disc. He's gonna look but my curiosity is killing me now. What's standard? It's a 2d Hard top.
If it's a disc car, I'm in, but I'm done monkeying around with four wheel drums and I don't want to bother with conversion unless someone had everything I need ready to go for reasonable money. I'd just go with another car first.
Thanks!
Ole' Ugly, my 1985 Gran Fury. Luke, my 39,000 mile 77 New Yorker, Darth, my 50,000 mile 60 New Yorker.
Re: C-body brake question [Re: BattleCruiser71] #2028388
03/10/16 10:20 AM
03/10/16 10:20 AM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
manual drums were standard in 70 I believe. power disc was a popular option though.
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: C-body brake question [Re: ViperDave] #2028391
03/10/16 10:47 AM
03/10/16 10:47 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Mu buddy's 69 Polara 500 convertible with factory 440 Magnum has power drum brakes, that is the only option the car doesn't have! shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: C-body brake question [Re: BattleCruiser71] #2028494
03/10/16 01:16 PM
03/10/16 01:16 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Almost all of them had power non is rare.Many had disc front as it was getting cheaper an popular in 70 as the 4 piston calipers were gone after 69.Ive never seen 4 piston in 70s.Usually even drums were power but my kid had a 67 newport that was manual drums. Rocky
Chrysler Firepower
Re: C-body brake question [Re: therocks] #2028529
03/10/16 02:13 PM
03/10/16 02:13 PM
dogdays Offline
dogdays  Offline
You must live in an enchanted place where C-body 2DHTs grow on trees. I can't remember the last time I saw one on the street.
I actually prefer the earlier version with the traditional C-pillar, not that weird hook of the later Elwood Engle cars.
R.
Re: C-body brake question [Re: BattleCruiser71] #2028536
03/10/16 02:18 PM
03/10/16 02:18 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
69 could be drum or single piston disc. Manual brakes would be rare.
If it's drums a 69-73 disc spindle is a bolt in swap, 73 being the preferred choice because the big bearing unicast rotor is cheaper. Calipers and pads are the same and can be bought anywhere.
68 was the last year for 4 piston Budd discs.
Kevin
Re: C-body brake question [Re: BattleCruiser71] #2028592
03/10/16 03:36 PM
03/10/16 03:36 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I had 3 Imps with 4 piston Budds.Allwere 69s.My 70s all had single pistons.Rocky
Chrysler Firepower
Re: C-body brake question [Re: BattleCruiser71] #2028600
03/10/16 03:45 PM
03/10/16 03:45 PM
KY
65pacecar Offline
65pacecar  Offline
KY
The SSBC kit for C bodies work well and you keep the original spindles. Also the 73 spindles are great if you can find them. Done s few of those and it's easy but getting hard to find. The SSBC is about like doing a normal brake job.
Re: C-body brake question [Re: therocks] #2028718
03/10/16 07:32 PM
03/10/16 07:32 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Imperials kept the BUDD 4 piston, disc brakes until 1969.
The 1968 "C" body cars were the last year for the BUDD's.
The single piston, Kelsey Hayes brakes started in 69, for the C's.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: C-body brake question [Re: Twostick] #2029697
03/12/16 11:14 AM
03/12/16 11:14 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Kevin
Even if the car is disc, I would do the '73 swap to get the better, cheaper rotors.
You have to swap spindles though because the bearings are different size on the '73 (as stated by twostick).
Way back when I had my '71 Newport, I did the '73 swap just for the rotors. At the time, the cost of ONE of the '71's rotors was equal to the cost of TWO of the '73's rotor. Being an original disc car, I only had to swap the spindles and rotors, everything else remained the same,
John
Re: C-body brake question [Re: SattyNoCar] #2029872
03/12/16 06:26 PM
03/12/16 06:26 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
Even if I couldn't get a set of 73 spindles I wouldn't keep drums over having to use the earlier more expensive rotor. For the amount of miles most of us put on these toys, rotors at twice the price is really not that big a deal. Realistically, how often do you change rotors?
I've been told that they are doing the pre 73 rotors in unicast now but can't confirm. If this is true it opens up a bigger pool of donor cars.
Another solution is to sleeve the pre 73 spindle up to the 73 bearing size so the 73 rotor will fit and using a 700r4 front pump seal for a grease seal. I think Dr Diff sells the sleeves or if you have access to a lathe, make your own.
Kevin
