Charger Front suspension #2028185
03/09/16 11:04 PM
03/09/16 11:04 PM
washington
TA Wanted Offline OP
washington
I picked up some parts the other day. The Guy says it was out of a low mile 69 charger R/T. I got an extra sway bar and Im not sure of its application. Any one recognize this part the diameter is 1 1/8. Is it a Hellwig part maybe? I appreciate any help on this. Thanks
Re: Charger Front suspension [Re: TA Wanted] #2028218
03/09/16 11:49 PM
03/09/16 11:49 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
I've never seen stand off brackets like that before on any of the 72 and earlier cars. And the bends are pretty extreme.
Hope someone can identify it. I'd like to know what it is for as well.
Re: Charger Front suspension [Re: TA Wanted] #2028633
03/10/16 04:56 PM
03/10/16 04:56 PM
Santa Fe Springs, CA
Jon @ Hotchkis Offline
The stamped bushings brackets remind me of something newer, but they don't look like a Durango or Dakota...
Hotchkis Performance
8633 Sorensen Ave.
Santa Fe Springs, CA 90670
Phone: 562-907-7757 x224
Fax: 562-907-7765
Hotchkis Performance East
9075 Highway 152
Mooresville, NC 28115
704-660-3060
Re: Charger Front suspension [Re: TA Wanted] #2028976
03/11/16 02:19 AM
03/11/16 02:19 AM
washington
washington
Thanks for all the comments. Another mystery part for my collection. The sway bar width looks similar to my EBody.
Re: Charger Front suspension [Re: TA Wanted] #2029149
03/11/16 12:56 PM
03/11/16 12:56 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
The bends and layout make it look like a rear bar. The brackets look like something off a front bar. Weird combo that is not a copy of any original mopar part.
Re: Charger Front suspension [Re: TA Wanted] #2029500
03/11/16 11:47 PM
03/11/16 11:47 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Look at the bushings up close on their sides and see if there are any casting numbers or Ford, Mopar, GM etc insignias.
The casting numbers are sometimes close to the part numbers. So posting them in the General section here might be someone familiar with part numbers, like Moparts people that work in dealership service are parts (or even on Google).
The casting number often can determine a rough idea of the date of the part application.
It looks like a factory sway bar setup to a truck or something. The blue bushing look OE as do the brackets.
Re: Charger Front suspension [Re: autoxcuda] #2031324
03/15/16 12:16 AM
03/15/16 12:16 AM
washington
washington
Thanks for all the ideas. Ill check it out in the morning...
