Wilwood rear brake install #2025937
03/06/16 08:29 PM
03/06/16 08:29 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
I just got a smokin deal on some Wilwood rear brakes but they have small bearing Ford brackets so I'm going to pick up some Mopar/Dana brackets. As far as I can tell they replace the flange on the "green" bearings an the instructions require you to remove the bearings then install the plates. I have Moser axles with snap ring type bearings that don't have an integral flange so I was wondering if the Wilwood brackets retain the axle bearing against the snap ring.It would be nice if I didn't have to remove the bearing and just drop the brackets over the axles then install the snap ring then slide the axle back in.
If anyone here has installed the drag type brakes please enlighten me.
Thanks up
Gus
64 Plymouth Savoy
Dana 60
Re: Wilwood rear brake install [Re: fourgearsavoy] #2026123
03/06/16 11:39 PM
03/06/16 11:39 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
They make 2 different brackets for Mopars. One is for the flange style bearing (which I have) and the other for the snap ring style you have.
Make sure you order the correct one.
Can't say anything about the install for yours but mine I was able to smack the flange off the bearing with a hammer and cut the flange off so I didn't have to press the bearings. After that the bracket then acts as the flange to hold the bearings in the axle.
Re: Wilwood rear brake install [Re: WILD BILL] #2026238
03/07/16 01:31 AM
03/07/16 01:31 AM
Rittman Ohio
Rittman Ohio
Thanks Bill
I really don't want to replace good bearings if I don't have to to use these brakes. I have to make a few measurements to order the correct brackets then I will call Wilwood to make sure I get the correct brackets.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Wilwood rear brake install [Re: fourgearsavoy] #2026325
03/07/16 09:23 AM
03/07/16 09:23 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I machined my brackets for a snap ring. But beware there are different hat offsets. Mock everything up first and make the caliper will center over the rotor. You can shim it in one direction but not the other.
Doug
Re: Wilwood rear brake install [Re: dvw] #2026370
03/07/16 11:55 AM
03/07/16 11:55 AM
Rittman Ohio
Rittman Ohio
Thanks Doug
I looked at the Ford brackets and the ID and the bolt patterns are very close to the Mopar setup so I can modify them to at least mock it up to check the hat offset. I might even be able to use them if I open up the ID of the bearing hole and have it machined for the snap ring like you did.
Gus beer
64 Plymouth Savoy
Dana 60
