Wilwood rear brake install
#2025937
03/06/16 08:29 PM
03/06/16 08:29 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I just got a smokin deal on some Wilwood rear brakes but they have small bearing Ford brackets so I'm going to pick up some Mopar/Dana brackets. As far as I can tell they replace the flange on the "green" bearings an the instructions require you to remove the bearings then install the plates. I have Moser axles with snap ring type bearings that don't have an integral flange so I was wondering if the Wilwood brackets retain the axle bearing against the snap ring.It would be nice if I didn't have to remove the bearing and just drop the brackets over the axles then install the snap ring then slide the axle back in. If anyone here has installed the drag type brakes please enlighten me. Thanks Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Wilwood rear brake install
[Re: WILD BILL]
#2026238
03/07/16 01:31 AM
03/07/16 01:31 AM
fourgearsavoy
Rittman Ohio
Thanks Bill I really don't want to replace good bearings if I don't have to to use these brakes. I have to make a few measurements to order the correct brackets then I will call Wilwood to make sure I get the correct brackets. Gus
[Re: dvw]
#2026370
03/07/16 11:55 AM
03/07/16 11:55 AM
fourgearsavoy
Rittman Ohio
Thanks Doug I looked at the Ford brackets and the ID and the bolt patterns are very close to the Mopar setup so I can modify them to at least mock it up to check the hat offset. I might even be able to use them if I open up the ID of the bearing hole and have it machined for the snap ring like you did. Gus
