why can't I get a good quality voltage reulator? #2025645
03/06/16 12:30 PM
03/06/16 12:30 PM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
My truck stopped charging about 2 weeks ago. noticed it on the way home one night (dim lights). next morn no start. charged my battery and went to work and put a meter on it ,sure enough no charge. got a new voltage reg from napa and it was charging again . a little high though about 15 volts. I let it go. by Saturday of that week (5 days) my battery blew up. Monday went back to work and checked it and was charging 18 volts. needless to say put in a new batt and voltage reg. still slightly over charging. fast forward to this sat and again over charging but caught it and unplugged the reg. back to square one. not that it couldn't be an issue but the alternator is about a year old.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: why can't I get a good quality voltage reulator? [Re: yella71] #2025652
03/06/16 12:46 PM
03/06/16 12:46 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Would probably help to give the year, make and model.
Careful, your character's showing!
Re: why can't I get a good quality voltage reulator? [Re: mopar346] #2025666
03/06/16 12:58 PM
03/06/16 12:58 PM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
sorry to me there all the same. 89 pick up with a diesel. same voltage reg from 70 to like 92 or so. and it's in my sig
Re: why can't I get a good quality voltage reulator? [Re: yella71] #2025668
03/06/16 01:00 PM
03/06/16 01:00 PM
Andrewh Offline
Andrewh  Offline
under charge or no charge, sure, bad reg.
2 showing over charge and I would start looking at the bulkhead connectors and checking sensing line voltage for a drop vs battery, or grounds to the vr.
Re: why can't I get a good quality voltage reulator? [Re: Andrewh] #2025687
03/06/16 01:19 PM
03/06/16 01:19 PM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
yep i'll check the wiring it was all good before the first reg went bad. after the second reg went in if you brought up the rpms it would charge in the 14.7 range which is where it should charge. the ground is good, first thing I always check on any mopar voltage reg.
Re: why can't I get a good quality voltage reulator? [Re: yella71] #2025711
03/06/16 01:59 PM
03/06/16 01:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Actually, not all the same. In 89 the gas trucks used the computer to control the charging, dunno about the diesels though. So the information is important.
If you have had two bad VR's then I'd look elsewhere.
Don't be the exception.
Re: why can't I get a good quality voltage reulator? [Re: Supercuda] #2025732
03/06/16 02:30 PM
03/06/16 02:30 PM
New Jersey, USA
Y
yella71 Offline OP
yella71  Offline OP
Y
New Jersey, USA
Yeah my Diesel has just a basic mopar electronic voltage reg. All of them now made in china.
Re: why can't I get a good quality voltage reulator? [Re: yella71] #2025890
03/06/16 07:42 PM
03/06/16 07:42 PM
nj
JAMESDART Offline
JAMESDART  Offline
nj
Yeah those regulators are terrible.
Re: why can't I get a good quality voltage reulator? [Re: JAMESDART] #2025916
03/06/16 08:07 PM
03/06/16 08:07 PM
#1 confirm that you have a good (not sulphated) battery in there (that is capable of being charged), that is fully charged. If it is that new one you should be good there (& likely fully charged if not over that by now!).
Re: why can't I get a good quality voltage reulator? [Re: yella71] #2025983
03/06/16 09:16 PM
03/06/16 09:16 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I would be checking my grounds and voltage feedback to the regulator.
Re: why can't I get a good quality voltage reulator? [Re: yella71] #2026034
03/06/16 10:15 PM
03/06/16 10:15 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I had the same problem wound up being the wire between the alternator and the voltage regulator having a really high resistance. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: why can't I get a good quality voltage reulator? [Re: astjp2] #2026091
03/06/16 11:16 PM
03/06/16 11:16 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Exactly my point!
Re: why can't I get a good quality voltage reulator? [Re: yella71] #2026145
03/07/16 12:00 AM
03/07/16 12:00 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
The timing of this thread is perfect. My B-van has been doing the same overcharging BS for awhile and it would come and go. This weekend I finally tore into it and after lots of metering and parts swapping nothing changed. (And YES that stupid VR was thoroughly grounded) As my last resort I made a test cable to bypass all the factory crap and lo and behold it starting charging perfectly @ 13.7 volts. plug in the original crap and its all over the place again. Measuring the key on power at the alternator and voltage regulator it was barely 11 volts just sitting there with the key on and not running. There was enough voltage drop through coming off the battery, through the bulkhead, ignition switch, back through the bulkhead and off to the rest of key-on 12volt power that the VR and alternator field could not get a clean consistent 12-13 volts so it was ramping up the voltage compensating thinking it was necessary.
Awhile ago I rewired the A/C clutch circuit to use the original power wire as the trigger for a relay because coming to idle the voltage drop was just enough that the A/C clutch would cut in and out. I'll probably do the same thing for the key-on 12 volt power circuit. Even with clean and greased connections theres just enough voltage drop in some cases to cause all sorts of gremlins that come and go.
Re: why can't I get a good quality voltage reulator? [Re: yella71] #2026168
03/07/16 12:16 AM
03/07/16 12:16 AM
Maryland
ro23_j Offline
ro23_j  Offline
Maryland
I have '91 diesel that had the same problem. I replaced the voltage regulator at least five times before the battery gave up. I checked all the grounds and even ran a separate ground from the regulator case to the battery. Still overcharging, so I replaced the alternator, made no difference.
There is a guy on the Turbo Diesel Register (TDR)website who has adjustable regulators for sale that he had made. I spoke to him on the phone and he told me how to test my charging system. I was not able to locate the cause but I bought one of his regulators, adjusted the voltage and haven't had a problem since. That was about two years ago.
His screen name over there is Mysteryman. You might want to check out some of his posts on TDR.
Re: why can't I get a good quality voltage reulator? [Re: yella71] #2026175
03/07/16 12:25 AM
03/07/16 12:25 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
