why can't I get a good quality voltage reulator?
#2025645
03/06/16 12:30 PM
03/06/16 12:30 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
My truck stopped charging about 2 weeks ago. noticed it on the way home one night (dim lights). next morn no start. charged my battery and went to work and put a meter on it ,sure enough no charge. got a new voltage reg from napa and it was charging again . a little high though about 15 volts. I let it go. by Saturday of that week (5 days) my battery blew up. Monday went back to work and checked it and was charging 18 volts. needless to say put in a new batt and voltage reg. still slightly over charging. fast forward to this sat and again over charging but caught it and unplugged the reg. back to square one. not that it couldn't be an issue but the alternator is about a year old.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
Re: why can't I get a good quality voltage reulator?
[Re: yella71]
#2025652
03/06/16 12:46 PM
03/06/16 12:46 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Would probably help to give the year, make and model.
Careful, your character's showing!
[Re: mopar346]
#2025666
03/06/16 12:58 PM
03/06/16 12:58 PM
yella71
New Jersey, USA
sorry to me there all the same. 89 pick up with a diesel. same voltage reg from 70 to like 92 or so. and it's in my sig
89 CTD pup
[Re: Andrewh]
#2025687
03/06/16 01:19 PM
03/06/16 01:19 PM
yella71
New Jersey, USA
yep i'll check the wiring it was all good before the first reg went bad. after the second reg went in if you brought up the rpms it would charge in the 14.7 range which is where it should charge. the ground is good, first thing I always check on any mopar voltage reg.
89 CTD pup
[Re: yella71]
#2025711
03/06/16 01:59 PM
03/06/16 01:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
sorry to me there all the same. 89 pick up with a diesel. same voltage reg from 70 to like 92 or so. and it's in my sig Actually, not all the same. In 89 the gas trucks used the computer to control the charging, dunno about the diesels though. So the information is important. If you have had two bad VR's then I'd look elsewhere.
[Re: Supercuda]
#2025732
03/06/16 02:30 PM
03/06/16 02:30 PM
yella71
New Jersey, USA
Yeah my Diesel has just a basic mopar electronic voltage reg. All of them now made in china.
89 CTD pup
[Re: JAMESDART]
#2025916
03/06/16 08:07 PM
03/06/16 08:07 PM
RapidRobert
#1 confirm that you have a good (not sulphated) battery in there (that is capable of being charged), that is fully charged. If it is that new one you should be good there (& likely fully charged if not over that by now!).
[Re: yella71]
#2025983
03/06/16 09:16 PM
03/06/16 09:16 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I would be checking my grounds and voltage feedback to the regulator.
[Re: yella71]
#2026034
03/06/16 10:15 PM
03/06/16 10:15 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I had the same problem wound up being the wire between the alternator and the voltage regulator having a really high resistance. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2026091
03/06/16 11:16 PM
03/06/16 11:16 PM
markz528
Morrow, OH
I had the same problem wound up being the wire between the alternator and the voltage regulator having a really high resistance. Tim Exactly my point!
