Dreaded electronics question, Blinker ! #2024055
03/03/16 08:51 PM
03/03/16 08:51 PM
Myrtle Beach, SC formerly the ...
340wedge Offline OP
340wedge  Offline OP
On my Duster I have the AO1 light package (fender mounted turn signals) Ralle Dash- Since I have owned the car, the driver's side "Dash" indicater flashes, but the driver's side fender indicator does not flash. The passenger side fender indicator works but the Dash indicator does Not flash. So the opposites sides work. I have replaced the bulbs, and the circuit board. Is is possible the circuit is such that if one fender indicator is not working it causes the dash indicator opposite side not to work?
1971 Sassy Grass Green Duster 340
2006 Charger Daytona GoMango
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024132
03/03/16 10:58 PM
03/03/16 10:58 PM
No not that. with the stalk down is the large filament in the 1157 DR side bulb blinking/stalk up is the pass side 1157 bulb blinking? If so, the fender mini bulb open is way forward with the connection between the 1157/fender mini bulb on each side respectively. First I would confirm the fender mini bulbs have continuity to ground and you might seperate/clean the bulkhead terminals. You can seperate the pull apart Turn signal/brake dangling harness under the st column & with stalk in nuetral/up/down see which wires respectively have continuity to each other. (dont have em memorized so more later) & that'll get the column out of the picture. that'd be a start (especially the grounds)
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024140
03/03/16 11:08 PM
03/03/16 11:08 PM
PA
70Duster Offline
70Duster  Offline
PA
I thought that on all the cars equipped with the fender mounted turn signal indicators, the dash turn signal indicators were not supposed to work.
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024155
03/03/16 11:27 PM
03/03/16 11:27 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 73 dart had them and they both worked.Inside and outside.Rocky
Chrysler Firepower
Re: Dreaded electronics question, Blinker ! [Re: RapidRobert] #2024162
03/03/16 11:36 PM
03/03/16 11:36 PM
340wedge Offline OP
340wedge  Offline OP
Thanks Rapid! I am going to start there and see. I am going to disconnect the wire to the fender mount and make sure that is grounded well too.
Re: Dreaded electronics question, Blinker ! [Re: therocks] #2024167
03/03/16 11:43 PM
03/03/16 11:43 PM
PA
70Duster Offline
70Duster  Offline
PA
That's interesting, Rocky. My parents bought a 1970 Satellite new in early 1971 and my Mom actually still owned that car until 2013. It had the fender mounted turn signal indicators and the inside dash indicators never functioned since day one. Makes me wonder if it was defective from the factory....
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024282
03/04/16 03:34 AM
03/04/16 03:34 AM
Castlegar, BC, Canada
That AMC Guy Offline
Quite possibly. I've had a '68 New Yorker, a '71 Dart Swinger and a '75 Valiant Brougham. All 3 had fender top turn indicators and all of them worked in conjunction with the dashboard indicators.
I would check the grounds at the fender indicators and check the pins on the circuit board of the gauge cluster.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024315
03/04/16 08:23 AM
03/04/16 08:23 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
I'm guessing burned out bulbs. Do the grille indicators work right?
Angry white pureblood male
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024377
03/04/16 11:41 AM
03/04/16 11:41 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
My 69 has fender mounted signals. Both dash and fender mounts work at same time.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024419
03/04/16 01:00 PM
03/04/16 01:00 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I forgot my 4 Imperails had fender mounts and the insides worked on them also.They were different though as they had hibeam indicators in them also.Might still have a couple in the garage somewhere.Rocky
Chrysler Firepower
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024420
03/04/16 01:00 PM
03/04/16 01:00 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I forgot my 4 Imperials had fender mounts and the insides worked on them also.They were different though as they had hibeam indicators in them also.Might still have a couple in the garage somewhere.Rocky
Chrysler Firepower
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024487
03/04/16 03:05 PM
03/04/16 03:05 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
1967 Satellite with fender indicators, had black tape over the dash bulb holes. LA built fall 66
Re: Dreaded electronics question, Blinker ! [Re: 70Duster] #2024501
03/04/16 03:19 PM
03/04/16 03:19 PM
pa.
dan9 Offline
dan9  Offline
pa.
I think they should both work. In Pennsylvania when those cars were new the only lights required to pass state inspection in the dash were turn signal lights and high beam indicator.
Re: Dreaded electronics question, Blinker ! [Re: dan9] #2024695
03/04/16 10:13 PM
03/04/16 10:13 PM
if the large filaments in the front dr/pass 1157 bulbs work when the stalk is activated (up/down) I'd find the open between them and the fender mini bulbs (& their grounds possibly) & get them working. that'd be a start & get that part squared away will give you confidence to dig into the hard(er) part (working up under the dash)
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024711
03/04/16 10:44 PM
03/04/16 10:44 PM
Brodheadsville Pa.
franko Offline
franko  Offline
Brodheadsville Pa.
I did not read all the replies but check the signal switch in the steering column .it can cause a lot of different problems if defective
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2024736
03/04/16 11:28 PM
03/04/16 11:28 PM
340wedge Offline OP
340wedge  Offline OP
I think I will have to investigate from the steering column up. I checked the small bulb in the fender blinker, and the wire and ground in the fender where it plugs into the harness, all was good. Has to be from the harness back.
Re: Dreaded electronics question, Blinker ! [Re: RapidRobert] #2024929
03/05/16 11:47 AM
03/05/16 11:47 AM
pa.
dan9 Offline
dan9  Offline
pa.
That's what I am thinking too. Wouldn't it make sense for the factory to get power for the fender mounted light from the 1157 wire? With a test light grounded properly and he sees power to the front lights then it is simply a wiring or bulb issue with the fender mounted light.
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2025126
03/05/16 05:45 PM
03/05/16 05:45 PM
ohio
ohio
Yes that's how the factory did it.
Re: Dreaded electronics question, Blinker ! [Re: 340wedge] #2025136
03/05/16 06:10 PM
03/05/16 06:10 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
All of the turning signal lites (dash, front, rear) are wired in parallel (+ side) when ON....
But each has its own ground, U need to check each socket for corrosion & bulb for continuity, plus the bulkhead connectors..
Just my $0.02.... wink
Re: Dreaded electronics question, Blinker ! [Re: Sinitro] #2025319
03/05/16 11:07 PM
03/05/16 11:07 PM
I agree. If the main park/turn/tail lamps all function properly, then it's probably a matter of either a ground, bad socket or bad wire for the fender top light and I'd be willing to put money on it being a broken pin on the cluster board for the dash light.
