Front tire suggestions.... #2023245
03/02/16 04:18 PM
03/02/16 04:18 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
I have the police spec wheels on my 1970 road runner convertible, currently 275-60R15 on the rear and 235-70R15 on the front.
I’m looking at a front tire upgrade and was wondering if a 235-60R15 on the front would look better or not.
I FINALLY have the (power)steering all straightened out and its driving and handling much better after 35 plus years.
Any other thoughts, pros or cons? ANY suggestions would be helpful.
1970 road runner Convertible
1 of 179
Re: Front tire suggestions.... [Re: njdevil2] #2023377
03/02/16 07:40 PM
03/02/16 07:40 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i'm looking for new fronts for my 69 as well and i believe, from the 100's of posts and searches, that the consensus leans towards a 235x65x15.
Re: Front tire suggestions.... [Re: mikemee1331] #2023578
03/03/16 12:59 AM
03/03/16 12:59 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Mine are smaller at 205/70/15. The one thing I do know is the backspace is more crucial when going wider on tire. I added a 1" spacer on the front of mine to move them out and they tried to hit at the front during a turn. I'd think a wider tread may try to do the same. Maybe look at how much clearance you currently have at the bottom front corners of the fender and see if there's enough room for more tread width... shruggy
...FAFO...
Re: Front tire suggestions.... [Re: njdevil2] #2023583
03/03/16 01:05 AM
03/03/16 01:05 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
He's not going wider, he's going shorter. 235 is the width, same for both choices, 70 or 65 or 60 is the aspect ratio (height is 70, or 65, or 60% of the width) 15 is rim diameter.
I ran P235/60R15's on the front of my M body, so not much help there as I never owned a Body of any sort.
Don't be the exception.
Re: Front tire suggestions.... [Re: njdevil2] #2023600
03/03/16 01:25 AM
03/03/16 01:25 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
235 60s look to short to me but I like a car to sit up like it's fixin to jump on somebody. I run 225 70s on the front of my B-bodies and love them. I have run 235 70s in the past and like them as well. I have 215 70s on my AAR cause I like the way it sits but I may go to 225 70s, I have a set of 235s 70s on 6.5 ralleys and just think they look big on it. They all seem to match up fine to my rear tires, 275 60s, L60s and N50s depending on which car and which day. twocents
Careful, your character's showing!
Re: Front tire suggestions.... [Re: njdevil2] #2023631
03/03/16 02:16 AM
03/03/16 02:16 AM
Kirkland, Washington
Pacnorthcuda Offline
I prefer to run the same aspect ratio in my cars
My 70 Cuda is 275/60/15 x 235/60/15 ........245's on the front rub.
I do think the perfect rear would be 275/55/15 (talking stock wheelwells and spring locations here) but the only tires are $500 each Avons!!! Not that I am not tempted!
Re: Front tire suggestions.... [Re: njdevil2] #2023736
03/03/16 12:08 PM
03/03/16 12:08 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
Aesthetically speaking, yeah, I was going for the rake look.
I have all new front and rear suspension no air shocks(FINALLY!!)
and I've seen different wheel/tire combos. I just not satisfied with the way the 70's look on the front.
I will probably go with the 235-60's....yeah, I'd be tempted to do the Avons.....but the price......yikes!!
1 of 179
Re: Front tire suggestions.... [Re: njdevil2] #2023780
03/03/16 01:08 PM
03/03/16 01:08 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
255-60/15 on the front of my 1970 Roadrunner, 275-60/15 on rear, no rubbing, looks tough.
Re: Front tire suggestions.... [Re: njdevil2] #2024048
03/03/16 08:40 PM
03/03/16 08:40 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
Looks good....
Still leaning toward the 235's though....
I'd LOVE to get more tire under the rear as well, but, I don't think there is much else I can put under there with the current wheels.
1 of 179
Re: Front tire suggestions.... [Re: 469runner] #2025327
03/05/16 11:16 PM
03/05/16 11:16 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
My car barley hooks up with 325/50-15 Nitto Drag Radials on the back. They are one of the only 15" tires with any kind of a high speed rating, and it's a "Y" rating at that = 186 mph. Anything smaller is just too squirrely on the street. No cutting or tubing was needed, but I am running a B-body rear end and Dr Diff's inset hangers.
On the front, I'm running 245/60-15's. They do rub slightly when I back out of the driveway, but not enough to trip on. The next set of front tires with be Avon's in the same size. They don't last as long, but they have a 149 mph speed rating.
Re: Front tire suggestions.... [Re: njdevil2] #2027856
03/09/16 02:40 PM
03/09/16 02:40 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
JBC - do the rear tires rub on the wheel wells?
That's a lot of tire!! I like it!!
1 of 179
Re: Front tire suggestions.... [Re: njdevil2] #2027870
03/09/16 03:07 PM
03/09/16 03:07 PM
central il.
second 70 Online content
second 70  Online Content
central il.
I run P225/70R-15 on the front and 275/60R/15 on the rear of my cuda. The 235/60/15 were just too short.
Re: Front tire suggestions.... [Re: jbc426] #2027881
03/09/16 03:18 PM
03/09/16 03:18 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
275/60 and 235/60 are becoming a pretty basic combo for muscle era cars. Both sizes are easily available from the few 15" tire manufacturers that are still out there aming tires, they are easy to get and don't cost an arm and leg.
Interesting combo that looks brutally wide. My Challenger is running MT SR (H Speed rated, btw) 26x12 rear and 26x10 front. I'd say that is somewhere close to 305/45 and 255/55 in metric terms. It doesn't looked as stuffed full of tire as your does, but I think rim offset and overall diameter may have some influence on that. I've also got a B body rear with 1" inboard springs.
Re: Front tire suggestions.... [Re: TC@HP2] #2027899
03/09/16 03:34 PM
03/09/16 03:34 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
70 b-BODY 225 70-15 is too tall. I always ran 245 60-15 front because they are very comparable to a F 60-15 or G 60-15.
My last 70 GTX had 235 60-15 front and 275 60-15 rear and the fronts just look too short to me.
Ron
Re: Front tire suggestions.... [Re: njdevil2] #2028740
03/10/16 07:57 PM
03/10/16 07:57 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
I like the stance, The 70's I have in the front strike me as being too tall.
I thought using the 235's would give more rake and a more muscular stance.
The 245's might be a bit too wide for the front.
1 of 179
Re: Front tire suggestions.... [Re: njdevil2] #2028837
03/10/16 10:32 PM
03/10/16 10:32 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
You don't have to follow what I say but I've had enough of these cars to know different.
Ron
Re: Front tire suggestions.... [Re: njdevil2] #2030919
03/14/16 02:17 PM
03/14/16 02:17 PM
Hightstown, NJ
njdevil2 Offline OP
njdevil2  Offline OP
Hightstown, NJ
I'll see if I can find some 245's....can you get me a head on shot on that so I can see it?
1 of 179
