Front tire suggestions....
#2023245
03/02/16 04:18 PM
03/02/16 04:18 PM
Posts: 457 Hightstown, NJ
njdevil2
Hightstown, NJ
I have the police spec wheels on my 1970 road runner convertible, currently 275-60R15 on the rear and 235-70R15 on the front.
I’m looking at a front tire upgrade and was wondering if a 235-60R15 on the front would look better or not.
I FINALLY have the (power)steering all straightened out and its driving and handling much better after 35 plus years.
Any other thoughts, pros or cons? ANY suggestions would be helpful.
1970 road runner Convertible 1 of 179
Re: Front tire suggestions....
[Re: njdevil2]
#2023583
03/03/16 01:05 AM
03/03/16 01:05 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
He's not going wider, he's going shorter. 235 is the width, same for both choices, 70 or 65 or 60 is the aspect ratio (height is 70, or 65, or 60% of the width) 15 is rim diameter.
I ran P235/60R15's on the front of my M body, so not much help there as I never owned a Body of any sort.
[Re: njdevil2]
#2023736
03/03/16 12:08 PM
03/03/16 12:08 PM
njdevil2
Hightstown, NJ
Aesthetically speaking, yeah, I was going for the rake look. I have all new front and rear suspension no air shocks(FINALLY!!) and I've seen different wheel/tire combos. I just not satisfied with the way the 70's look on the front.
I will probably go with the 235-60's....yeah, I'd be tempted to do the Avons.....but the price......yikes!!
[Re: njdevil2]
#2024048
03/03/16 08:40 PM
03/03/16 08:40 PM
njdevil2
Hightstown, NJ
Looks good....
Still leaning toward the 235's though....
I'd LOVE to get more tire under the rear as well, but, I don't think there is much else I can put under there with the current wheels.
[Re: 469runner]
#2025327
03/05/16 11:16 PM
03/05/16 11:16 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
My car barley hooks up with 325/50-15 Nitto Drag Radials on the back. They are one of the only 15" tires with any kind of a high speed rating, and it's a "Y" rating at that = 186 mph. Anything smaller is just too squirrely on the street. No cutting or tubing was needed, but I am running a B-body rear end and Dr Diff's inset hangers.
On the front, I'm running 245/60-15's. They do rub slightly when I back out of the driveway, but not enough to trip on. The next set of front tires with be Avon's in the same size. They don't last as long, but they have a 149 mph speed rating.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: njdevil2]
#2027856
03/09/16 02:40 PM
03/09/16 02:40 PM
njdevil2
Hightstown, NJ
JBC - do the rear tires rub on the wheel wells?
That's a lot of tire!! I like it!!
[Re: jbc426]
#2027881
03/09/16 03:18 PM
03/09/16 03:18 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
I’m looking at a front tire upgrade and was wondering if a 235-60R15 on the front would look better or not. 275/60 and 235/60 are becoming a pretty basic combo for muscle era cars. Both sizes are easily available from the few 15" tire manufacturers that are still out there aming tires, they are easy to get and don't cost an arm and leg. My car barley hooks up with 325/50-15 Nitto Drag Radials on the back. They are one of the only 15" tires with any kind of a high speed rating, and it's a "Y" rating at that = 186 mph. Anything smaller is just too squirrely on the street. No cutting or tubing was needed, but I am running a B-body rear end and Dr Diff's inset hangers.
On the front, I'm running 245/60-15's. They do rub slightly when I back out of the driveway, but not enough to trip on. The next set of front tires with be Avon's in the same size. They don't last as long, but they have a 149 mph speed rating. Interesting combo that looks brutally wide. My Challenger is running MT SR (H Speed rated, btw) 26x12 rear and 26x10 front. I'd say that is somewhere close to 305/45 and 255/55 in metric terms. It doesn't looked as stuffed full of tire as your does, but I think rim offset and overall diameter may have some influence on that. I've also got a B body rear with 1" inboard springs.
[Re: njdevil2]
#2028740
03/10/16 07:57 PM
03/10/16 07:57 PM
njdevil2
Hightstown, NJ
I like the stance, The 70's I have in the front strike me as being too tall.
I thought using the 235's would give more rake and a more muscular stance.
The 245's might be a bit too wide for the front.
[Re: njdevil2]
#2028837
03/10/16 10:32 PM
03/10/16 10:32 PM
Posts: 6,224 JERSEY
RJS
JERSEY
The 245's might be a bit too wide for the front. You don't have to follow what I say but I've had enough of these cars to know different. Ron
[Re: njdevil2]
#2030919
03/14/16 02:17 PM
03/14/16 02:17 PM
njdevil2
Hightstown, NJ
I'll see if I can find some 245's....can you get me a head on shot on that so I can see it?
