Re: carnage at the dyno
[Re: cudaman1969]
#2027418
03/08/16 08:26 PM
03/08/16 08:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
This discussion is getting up there to the pinion angle-8-3/4 level, wow, only on moparts. Kinda fun, yes? Whats wrong with trying to help the guy out.. he had a issue that he cant find at the moment
[Re: MR_P_BODY]
#2027442
03/08/16 08:50 PM
03/08/16 08:50 PM
Posts: 8,250 fredericksburg,va
cudaman1969
fredericksburg,va
This discussion is getting up there to the pinion angle-8-3/4 level, wow, only on moparts. Kinda fun, yes? Whats wrong with trying to help the guy out.. he had a issue that he cant find at the moment Nothing wrong with trying, but all we have are photos and what he's told us. WE can't inspect these parts up close like a good machinist can, there's a ton of things that needs measuring-inspection, so we're all just shooting in the dark. It's a wonder he's not confused with all the conflicting opinions of just the bearings, let alone the rest of the engine. A good engine builder-machinist is his only recourse to learn what happened. I wish him best of luck.
[Re: mopar dave]
#2027451
03/08/16 08:58 PM
03/08/16 08:58 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
The crank never got oil, why?
Mopar to the bone!!!
[Re: ]
#2027574
03/08/16 11:34 PM
03/08/16 11:34 PM
Posts: 4,255 Canada
WO23Coronet
Canada
What a weak [censored] box! Kick rocks goof
[Re: mopar dave]
#2027600
03/09/16 12:00 AM
03/09/16 12:00 AM
Posts: 4,457 Washington
madscientist
Washington
A machinest/Dyno operator looked at everything and took some measures. Said the bearings show heat. Had pressure but no flow. I don't understand. I did find the rear main cap cracked in two places so the block is junk. I'm putting this behind me. Thanks for trying to help. I will never modified another engine block oiling system. Promise I seriously doubt that you mods killed it.
[Re: mopar dave]
#2027617
03/09/16 12:27 AM
03/09/16 12:27 AM
72Swinger
Nebraska
You swung for the fence and got bit, it happens. Don't hang your head down at all. You came on here and put your dilly on the table and it shows you have a pair. Also the cracked rear cap could've been the whole problem. Ok I'm gonna put this thread behind me now to.
[Re: mopar dave]
#2027704
03/09/16 03:17 AM
03/09/16 03:17 AM
madscientist
Washington
That whole deal is a bummer, as I am right behind you. I should be on the dyno soon.
Can't say I blame you for just moving on.
[Re: cudaman1969]
#2027805
03/09/16 12:37 PM
03/09/16 12:37 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
This discussion is getting up there to the pinion angle-8-3/4 level, wow, only on moparts. Kinda fun, yes? Whats wrong with trying to help the guy out.. he had a issue that he cant find at the moment Nothing wrong with trying, but all we have are photos and what he's told us. WE can't inspect these parts up close like a good machinist can, there's a ton of things that needs measuring-inspection, so we're all just shooting in the dark. It's a wonder he's not confused with all the conflicting opinions of just the bearings, let alone the rest of the engine. A good engine builder-machinist is his only recourse to learn what happened. I wish him best of luck. Sounds like a good reason to shut this part of the board down Or only allow ... Guess my HP threads ....
[Re: mopar dave]
#2027849
03/09/16 02:14 PM
03/09/16 02:14 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I had one of the short white purolator filters fail on me also. My oil pressure gauge got very sluggish. I was just a few miles from home so I came home and swapped the filter and it fixed it.
I have heard purolator makes the mopar filters, I have used lots of those with no trouble but the one purolator cheapo I ran failed.
68 Barracuda Formula S 340
