Page 14 of 16 1 2 12 13 14 15 16
Re: carnage at the dyno [Re: mopar dave] #2027408
03/08/16 08:14 PM
03/08/16 08:14 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
This discussion is getting up there to the pinion angle-8-3/4 level, wow, only on moparts. Kinda fun, yes?
Re: carnage at the dyno [Re: mopar dave] #2027414
03/08/16 08:19 PM
03/08/16 08:19 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Look for witness marks on the trustside of the rods. If the cap is not inline with the rod it will often show up in the witness marks between the rod and crank sides; uneven from side to side. Check the others that are not broken! Also look for uneven wear on the other rodbearings.
Re: carnage at the dyno [Re: cudaman1969] #2027418
03/08/16 08:26 PM
03/08/16 08:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats wrong with trying to help the guy out..
he had a issue that he cant find at the moment
wave
Re: carnage at the dyno [Re: MR_P_BODY] #2027442
03/08/16 08:50 PM
03/08/16 08:50 PM
fredericksburg,va
fredericksburg,va
wave
Nothing wrong with trying, but all we have are photos and what he's told us. WE can't inspect these parts up close like a good machinist can, there's a ton of things that needs measuring-inspection, so we're all just shooting in the dark. It's a wonder he's not confused with all the conflicting opinions of just the bearings, let alone the rest of the engine. A good engine builder-machinist is his only recourse to learn what happened. I wish him best of luck.
Re: carnage at the dyno [Re: mopar dave] #2027451
03/08/16 08:58 PM
03/08/16 08:58 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The crank never got oil, why?
Mopar to the bone!!!
Re: carnage at the dyno [Re: 72Swinger] #2027537
03/08/16 10:41 PM
03/08/16 10:41 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
A machinest/Dyno operator looked at everything and took some measures. Said the bearings show heat. Had pressure but no flow. I don't understand. I did find the rear main cap cracked in two places so the block is junk. I'm putting this behind me. Thanks for trying to help. I will never modified another engine block oiling system. Promise
Re: carnage at the dyno [Re: ] #2027574
03/08/16 11:34 PM
03/08/16 11:34 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Originally Posted By Pimp
What a weak [censored] box!
Kick rocks goof
Re: carnage at the dyno [Re: mopar dave] #2027600
03/09/16 12:00 AM
03/09/16 12:00 AM
Washington
madscientist Offline
Washington
I seriously doubt that you mods killed it.
Re: carnage at the dyno [Re: ] #2027609
03/09/16 12:19 AM
03/09/16 12:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What a DICK.. a new ASSS hole
wave
Re: carnage at the dyno [Re: mopar dave] #2027617
03/09/16 12:27 AM
03/09/16 12:27 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You swung for the fence and got bit, it happens. Don't hang your head down at all. You came on here and put your dilly on the table and it shows you have a pair. Also the cracked rear cap could've been the whole problem. Ok I'm gonna put this thread behind me now to.
Re: carnage at the dyno [Re: ] #2027627
03/09/16 12:36 AM
03/09/16 12:36 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
troll
Re: carnage at the dyno [Re: 72Swinger] #2027643
03/09/16 01:18 AM
03/09/16 01:18 AM
Mt Morris Michigan
Mt Morris Michigan
I have never lost an engine in my life, including Chevy's. First time for everything. Moving on to big block world. Thank you for all your help guys.
Re: carnage at the dyno [Re: mopar dave] #2027648
03/09/16 01:23 AM
03/09/16 01:23 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Dave sorry your thread has gone in the ditch. I hope you find what caused your issues. Step back up to the plate and keep swinging, you'll hit out of the park.
Re: carnage at the dyno [Re: justinp61] #2027650
03/09/16 01:26 AM
03/09/16 01:26 AM
Mt Morris Michigan
Mt Morris Michigan
Yeah I understand. There's been enough suggestions said here. Its all good.
Re: carnage at the dyno [Re: mopar dave] #2027704
03/09/16 03:17 AM
03/09/16 03:17 AM
Washington
Washington
That whole deal is a bummer, as I am right behind you. I should be on the dyno soon.
Can't say I blame you for just moving on.
Re: carnage at the dyno [Re: madscientist] #2027707
03/09/16 03:24 AM
03/09/16 03:24 AM
Mt Morris Michigan
Mt Morris Michigan
Good luck to you. Im sure everything will go fine. My deal was just a fluke.
Re: carnage at the dyno [Re: mopar dave] #2027802
03/09/16 12:35 PM
03/09/16 12:35 PM
Mt Morris Michigan
Mt Morris Michigan
Anyone looking for any small block performance parts i will have some in the for sale section in the coming weeks. Just have to get things cleaned up first. indy 360-1 fully ported,indy intake ported,sheet metal valve covers with BLP spray bars,hedman race headers etc. I think this issue will go down as wrong oil filter and wrong oil for now.
Re: carnage at the dyno [Re: cudaman1969] #2027805
03/09/16 12:37 PM
03/09/16 12:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
wave
Sounds like a good reason to shut this part of the board down
Or only allow ... Guess my HP threads ....
Re: carnage at the dyno [Re: mopar dave] #2027843
03/09/16 01:54 PM
03/09/16 01:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Though I hate to see anyone blow anything up, the forensics are interesting to me. Let's face it not many of us build engines by the dozens. Every thing learned will make us all better engine builders.
Doug
Re: carnage at the dyno [Re: mopar dave] #2027849
03/09/16 02:14 PM
03/09/16 02:14 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had one of the short white purolator filters fail on me also. My oil pressure gauge got very sluggish. I was just a few miles from home so I came home and swapped the filter and it fixed it.
I have heard purolator makes the mopar filters, I have used lots of those with no trouble but the one purolator cheapo I ran failed.
68 Barracuda Formula S 340
