69 383 numbers #2021193
02/28/16 12:16 PM
02/28/16 12:16 PM
Loganville GA.
K
kdsmith07 Offline OP
K
Loganville GA.
i just picked up a 69 383 hp and was wondering what it came in originally.the rail # is 9A282234.thanks for any info,kent
Re: 69 383 numbers [Re: kdsmith07] #2021197
02/28/16 12:20 PM
02/28/16 12:20 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
1969 B-body from Lynch Road.
Someone that tracks cars from that plant may be able to narrow it down for you some.
Re: 69 383 numbers [Re: kdsmith07] #2021475
02/28/16 08:19 PM
02/28/16 08:19 PM
Loganville GA.
K
K
Loganville GA.
thank you for the reply.i was thinking maybe the car is still around.you never know.
Re: 69 383 numbers [Re: kdsmith07] #2021775
02/29/16 10:51 AM
02/29/16 10:51 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
It's probable it came from a Belvedere based car. Belvedere, Satellite, Sport Satellite or Road Runner.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 69 383 numbers [Re: 69CoronetRT] #2021847
02/29/16 01:38 PM
02/29/16 01:38 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Could have been a SuperBee too. Any evidence of original paint left? Road Runner and SuperBee would have been painted Street Hemi Orange.
Re: 69 383 numbers [Re: Pynzo] #2021926
02/29/16 04:09 PM
02/29/16 04:09 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
From what I can tell, that VIN range would be Belvedere based.
the 383 HP would have been available in most all Belevedere and Coronet based cars depending on how the car was equipped. The HP variant was not strictly limited to Road Runners or Super Bees.
Seeking:
Re: 69 383 numbers [Re: 69CoronetRT] #2021940
02/29/16 04:44 PM
02/29/16 04:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Paint color of the motor would help here .
I need to look thru pictures I have to see what was stamped on the pad of a 68 383 4bbl , non Road Runner, engine that was in the 68 Sport Satellite 'vert I owned.
Re: 69 383 numbers [Re: kdsmith07] #2022096
02/29/16 09:05 PM
02/29/16 09:05 PM
Loganville GA.
K
K
Loganville GA.
i can't find any original paint as the motor and trans are purple.i'll try and scrape some off tomm.thanks for the replies.it's much appreciated,kent
Re: 69 383 numbers [Re: kdsmith07] #2022099
02/29/16 09:07 PM
02/29/16 09:07 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Is it stamped HP on the pad or are you just presuming it is a HP assembly?
Seeking:
Re: 69 383 numbers [Re: kdsmith07] #2022104
02/29/16 09:19 PM
02/29/16 09:19 PM
Loganville GA.
K
K
Loganville GA.
the pad says E 383 then below that is a 5 28?and HP in the bottom right corner.that's all i see.
Re: 69 383 numbers [Re: kdsmith07] #2022578
03/01/16 02:00 PM
03/01/16 02:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Definitely a 335HP engine then .
