Page 2 of 3 1 2 3
Re: 440 block [Re: bonefish] #2020474
02/26/16 10:31 PM
02/26/16 10:31 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Well, free is certainly better than $700 wink
Re: 440 block [Re: Thumperdart] #2020488
02/26/16 10:51 PM
02/26/16 10:51 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Originally Posted By Thumperdart
Several years ago you could get complete motors and trannies for $200-$300 dollars...........
Hell, I used to buy whole cars cheaper than that. My first race engine, I bought the block from a Plymouth dealer, paid $250 for a brand new block.
[image][/image]
Re: 440 block [Re: sgcuda] #2020742
02/27/16 02:24 PM
02/27/16 02:24 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Show off................. laugh2
Re: 440 block [Re: Thumperdart] #2020814
02/27/16 04:27 PM
02/27/16 04:27 PM
dogdays Offline
dogdays  Offline
used to...................................meaningless.
R.
Re: 440 block [Re: bonefish] #2020816
02/27/16 04:41 PM
02/27/16 04:41 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Just sold two 69 blocks and one 70 for $300 each and they were .030 over. I sold a thick web 78 block standard bore for $450 Pre 68 blocks and 72 and later seem to go cheaper.
Re: 440 block [Re: R/T1968R/T] #2020823
02/27/16 04:58 PM
02/27/16 04:58 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
anyone hear of one in Fl. HOOK ME UP
Re: 440 block [Re: bonefish] #2020966
02/27/16 10:20 PM
02/27/16 10:20 PM
fullmetaljacket Offline
Good ones have the strengthening ribs on the exterior of the block.
Re: 440 block [Re: bonefish] #2020981
02/27/16 10:52 PM
02/27/16 10:52 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I have 6, maybe 7, it's been awhile since I've looked at them. I want to keep the 2 HP stamped ones I have and 2 of the LPs. Phrased like a TV sales ad, "Yours today for only $349.99". Problem is they're 250 miles from you, stashed in a storage unit in Leesburg.
If you can't find anything closer, text me (not a voice mail I'll never hear), I'll PM you my number.
Re: 440 block [Re: bonefish] #2021064
02/28/16 01:09 AM
02/28/16 01:09 AM
WI
mopar873 Offline
mopar873  Offline
WI
Wisconsin must still be land of the cheap. 440s are easy to find. Fwiw, I just sold a "630" standard bore 400 block for $200. That's about average for up here. You can still find lots of cars for a few hundred bucks and pull the engine and the 727.
Re: 440 block [Re: mopar873] #2021085
02/28/16 02:14 AM
02/28/16 02:14 AM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Any of the pre-66' big blocks up there (361,383,413)? grin
fury
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 440 block [Re: bonefish] #2021163
02/28/16 10:33 AM
02/28/16 10:33 AM
WI
mopar873 Offline
mopar873  Offline
WI
Once in awhile you can catch a 413 for a good deal.
Re: 440 block [Re: bonefish] #2021366
02/28/16 04:19 PM
02/28/16 04:19 PM
oregon
sproracer Offline
sproracer  Offline
oregon
The best 440 block is from the early 70's most likely from a motorhome. The number stamped on the side of the block is 4006630-440 that is the one with the thicker webs. after you get it torn down, look for core shift. then mag the block, if all of that is good, then proceed. the HP stamp is useless, only has to do with factory work shifts or some such crap, nothing to do with high performance. If you are just starting out, then I agree with Cab Burge, get a 400 block and build it, much better foundation for your performance build.
Re: 440 block [Re: sproracer] #2021387
02/28/16 04:38 PM
02/28/16 04:38 PM
Kirkland, Washington
Pacnorthcuda Offline
The HP stamp DOES denote a factory high performance engine. Nothing different about the block itself (other than the stamp) but it was assembled with different pistons/cam etc.
An HP block was cast on day shift. An HP2 block was cast on swing shift.
Re: 440 block [Re: Pacnorthcuda] #2021563
02/28/16 11:14 PM
02/28/16 11:14 PM
oregon
sproracer Offline
sproracer  Offline
oregon
I was commenting on the 440 engine block. But thank you for the clarification about the factory internals.
Re: 440 block [Re: Pacnorthcuda] #2021570
02/28/16 11:26 PM
02/28/16 11:26 PM
Western Washington
Sixgun Offline
Sixgun  Offline
Western Washington
Hey Greg!All the 1968 and earlier HP motors I have seen (maybe a couple dozen)were ALL "HP"
All the Big rod motors were 69 casting and later and stamped "HP2"(including 2 genuine 3 bolt cam six pack motors)
FWIW. My two cents...
I'm 55 now, no time to waste. Not a week goes by that I don't hear about someone passing on.Let's get out there,smoke some tires,have a beer with a good friend,do what you have always wanted to do.I am pretty sure no one will ever say on their deathbed "gee I'm glad my life was calm and boring"
Re: 440 block [Re: Sixgun] #2021652
02/29/16 01:50 AM
02/29/16 01:50 AM
Hey Case,good to see you post. Yes the 'HP2 means six pack, or at least six pack rods'
Seems to live on.
We gotta go shootin!
Re: 440 block [Re: fullmetaljacket] #2021679
02/29/16 02:32 AM
02/29/16 02:32 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
That just means they are later model. The ribs were added in 69 I believe. Also most believe and it has even been printed by Mopar, that later blocks are thin wall. I sonic checked a ton of them, from all years. I have found none of significantly thinner casting thickness, regardless of year.
Re: 440 block [Re: Monte_Smith] #2021685
02/29/16 02:43 AM
02/29/16 02:43 AM
Good thing since my block is a 69' with the rib job and originally out of a station wagon.
Re: 440 block [Re: bonefish] #2021687
02/29/16 02:49 AM
02/29/16 02:49 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Only reason I want a couple 440s is for muscle car builds.
Race stuff I already have a couple 230 400 blocks thoroughly checked and bagged that I'm starting with. Once I progress to where I need an aftermarket block I'll order a KB.
Re: 440 block [Re: n20mstr] #2023006
03/02/16 03:45 AM
03/02/16 03:45 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
Metro Detroit has 440's and 400's pop up on Craigslist all the time. Over the past 10 years I can tell you that I have never paid more than 200 dollars for a bare block. Lately I've seen the prices for long blocks up to 400-1200 dollars. Unfortunately the good deals are typically the project that never happened and the survivors just want it out of grandmas garage...
Page 2 of 3 1 2 3
