66 B Body brake pedal heigth #2021587
02/28/16 11:45 PM
02/28/16 11:45 PM
Alvadore OR
Acme Rocket Offline OP
Alvadore OR
Hello. Im working on a friends 66 Coronet 383 4 speed car. The brake pedal and clutch pedals are not the same height. The brake pedal is much lower than the clutch pedal. I looked under the dash and the both pedals are coming back to the stop (clutch) and brake light switch (brake). everything appears to be factory and all in its place. There is some additional linkage (bell crank) on the brake pedal that Im not use to seeing. It is a power brake car. Is this normal on a power brake car? Im stumped because as I said it all looks factory and like it belongs.
Thanks Seth
Re: 66 B Body brake pedal heigth [Re: Acme Rocket] #2021745
02/29/16 07:59 AM
02/29/16 07:59 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Yep,it's noral
Angry white pureblood male
Re: 66 B Body brake pedal heigth [Re: Acme Rocket] #2021801
02/29/16 12:15 PM
02/29/16 12:15 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Normal for power brakes
Re: 66 B Body brake pedal heigth [Re: Acme Rocket] #2022980
03/02/16 02:17 AM
03/02/16 02:17 AM
Alvadore OR
Alvadore OR
Ok thanks guys!
