Hello. Im working on a friends 66 Coronet 383 4 speed car. The brake pedal and clutch pedals are not the same height. The brake pedal is much lower than the clutch pedal. I looked under the dash and the both pedals are coming back to the stop (clutch) and brake light switch (brake). everything appears to be factory and all in its place. There is some additional linkage (bell crank) on the brake pedal that Im not use to seeing. It is a power brake car. Is this normal on a power brake car? Im stumped because as I said it all looks factory and like it belongs.
Thanks Seth
