315 Drag Radial Guys...........Step in. #2021195
02/28/16 12:17 PM
02/28/16 12:17 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
What width rim do you guys run, meaning what is the widest rim you would run with a set of 315's?
And how do you secure them to the rim, do you use bead locks or screws or?
Thinking of going this route....But the car makes a ton of torque.
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021198
02/28/16 12:24 PM
02/28/16 12:24 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Some run 15", I think 14" is still the most common
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021203
02/28/16 12:33 PM
02/28/16 12:33 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
One of my coworkers runs an x275 car, it seems all of the competitive guys use beadlocks. Not sure if it's functionally better or just easier for tire changes without a machine though.
Re: 315 Drag Radial Guys...........Step in. [Re: Defbob] #2021205
02/28/16 12:37 PM
02/28/16 12:37 PM
Dragula Offline OP
Dragula  Offline OP
Really that wide for a tire with 11" tread?
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021211
02/28/16 12:54 PM
02/28/16 12:54 PM
Parts unknown
590 Challenger Offline
Parts unknown
I'm looking to get some 13" bead locks made. As wide as I can go in my local class. I've seen many on 14's, I seen one on a 15, after seeing it , I would not try it. 12 is pretty common. Current wheels the tires are glued on
Re: 315 Drag Radial Guys...........Step in. [Re: 590 Challenger] #2021223
02/28/16 01:24 PM
02/28/16 01:24 PM
Dragula Offline OP
Dragula  Offline OP
Why the bead locks and not rim screws?
My current rims are 15 wide, and I am sure that is too wide for these. I was thinking 12, but wasn't sure.
Got a link to the tires? I had it saved in my favorites and it says no longer available. Not sure what is going on with M&T, but if I am going to give Drag Week a serious look-n-see, I will have to switch to a set of these and I need tires anyways this year.
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021233
02/28/16 01:40 PM
02/28/16 01:40 PM
Parts unknown
Parts unknown
You should not use screws on radials, it can tear the bead apart. Dump the 15's and buy the 12's. M/T old 315's are on the way out, the new 315 Pros are just becoming available. Take a look for those, I'm sure you will like them
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021234
02/28/16 01:46 PM
02/28/16 01:46 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Absolutely no screws! Use high tack on the bead, permatex makes it
Re: 315 Drag Radial Guys...........Step in. [Re: SpareParts] #2021292
02/28/16 02:52 PM
02/28/16 02:52 PM
Dragula Offline OP
Dragula  Offline OP
Yeah, I am having trouble finding the M&T in a 315 listed on Summit or Jegs.
My real problem then becomes how much offset can a rim take?....My Dana 60 is old school short, and most of the 12" will be out towards the fender lip...
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021319
02/28/16 03:27 PM
02/28/16 03:27 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
I run a 12" rim with my 315's.Wouldn't want to run anything wider imo.
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021338
02/28/16 03:41 PM
02/28/16 03:41 PM
Dragula Offline OP
Dragula  Offline OP
I think I am done, didn't see anything with a real short back space....I now remember why my rims have been on my car so long.....Drag radials are made for street cars...Not Pro-street cars.
Cause I can't get a short enough back space with a 12" rim!....All of the ones I looked at listed as 4.5 as the shortest. I think that is what I run with a 15" wide rim!
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021362
02/28/16 04:14 PM
02/28/16 04:14 PM
Parts unknown
Parts unknown
I had some 14.5 32's on mine as a street car. Champion makes 3.5 inch back space for a 12" (or larger wheel)....I bet they would go smaller if you ask
Re: 315 Drag Radial Guys...........Step in. [Re: 590 Challenger] #2021368
02/28/16 04:21 PM
02/28/16 04:21 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
On Mickey Thompson website they recommend a 9.5 - 11.0 rim for a 315-60-15.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: 315 Drag Radial Guys...........Step in. [Re: steve660] #2021391
02/28/16 04:50 PM
02/28/16 04:50 PM
Parts unknown
Parts unknown
Yes I know, and I made a mistake by going by that. Maybe it's for leagle resons from people not using bead locks??? I went out and bought some 10" wheels. I'm the only person in my class using them. They explained to me the wider wheel lets the tire flatten out for more rubber on the ground. Here is a pic of them on a 10" wheel. As you can see by the dust from rolling it around the shop floor, there is only 7 1/2" of rubber hitting the ground
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021404
02/28/16 05:05 PM
02/28/16 05:05 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Most 315 class "hitters" put the tires on 14 or 15 wide beadlock wheels. We use 12s, but only because the car won't hold wider. Beadlocks support the sidewall much better than screws, stiffening the sidewall even more, plus as mentioned above, you shouldn't use screws in radial beads. These tires do NOT slip. They are hooked or spinning. Screws will rip out on a hard leaving car. I would never trust glue.......of course we go low 1.0 60fts
Bogart, Holeshot, Champion and some others will make whatever you want. Last year when Murder Nova and Chief put radials on their cars for the first time, to make them "look" right, some company built them some wheels with basically NO offset. Don't remember which company it was, but can find out
Re: 315 Drag Radial Guys...........Step in. [Re: Monte_Smith] #2021438
02/28/16 06:35 PM
02/28/16 06:35 PM
Dragula Offline OP
Dragula  Offline OP
I won't be anywhere near a 1.0 anything in 60ft....Hoping for around a 1.30ish...Made too many changes to know what it will run.
Yeah finding a set of bead locks is going to be tough, let alone a tad expensive. I looked up a few on YB and saw what they looked like with too wide of a rim....Looks like 12-13 wide is pretty close. I can shoot for 12" and go from there.
I really like the new Mickey Pro-5 ET Drag Wheels....Those look awesome, and a little nostalgic. My guess is I would need 2.5 to 3.5 back spacing, might even be 1.5...I could buy the tires and then figure it out, unless someone has a set that's totally shot I can have. I just don't want it to look funny tucked way too far under the car if I go this route.
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021456
02/28/16 07:38 PM
02/28/16 07:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why not run the Hoosier qtp?
Re: 315 Drag Radial Guys...........Step in. [Re: Thumperdart] #2021496
02/28/16 09:01 PM
02/28/16 09:01 PM
Dragula Offline OP
Dragula  Offline OP
Not sure if the current ones are the same compound I had years ago, but the M&T ET Streets are way better when I switched. Been using those in 31x16.5 for ever now. Might just put another set on at this point. I thought it would be easier to find a reasonably priced set of rims and go DR 315's till I realized how little back spacing I use......Not looking easy to do with my setup unless I want to spend $3200
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021503
02/28/16 09:13 PM
02/28/16 09:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: 315 Drag Radial Guys...........Step in. [Re: Dragula] #2021506
02/28/16 09:18 PM
02/28/16 09:18 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
Like others have said DO NOT USE SCREWS.
I have 28x10.5's on a 12 inch wheel.
Centerline wheels you can get with 3 3/8 BS
